Duster Front Door Window Hardware/Misc. Parts
CE69
Active Member
Rating - 0%
0   0   0
Have a 71 Duster and in need of front door window hardware. The 2 piece plastic bushings and screws that bolt the window to the regulator, (4 per window) and the window stops that bolt to the front and back of the window, (2 per side).
Also looking for a stock grille moulding. Theres two and I don't know if the are the same, but I need the lower one. They sit in the inside part of the grille, upper and lower and they are real thin, about a 1/4". They have metal tabs on it to hold it in place. Not the big upper and lower mouldings that screw on.
One more part. One or both front side marker lens, amber in color.
All parts are for a 71 Duster and I'm only looking for decent, driver quality parts. They don't need to be perfect or NOS. As I will probably be selling the car when I get it back together and painted.
Please let me know what you have or where I can get them.
Thanks
Thanks
I have a 72 Duster I'll check the parts tomorrow.
Thanks! My hope is alive.
I'm waiting to hear from another member that wants the regulator out of that door so I can take it all out at one time.Door still has the door pad and panel on it so I can't see inside. Thanks-----Roy
Do you have a pic of the parts you need? I have everything from a 74 Duster I parted out just sitting on the floor that I dont need and will get rid of If you need it. Greg
Thanks SG, If you only have one side, I need both so if you don't mind, I would like to get them all in one place. Crackedback said he might have it all so I will PM him to see what he has. I will keep you in mind if he doesn't and Thank You for your help. Chad
Thanks, If the other members don't have them I will take some pics them. I don't know if they will be the same but its worth a shot.
I likely have everything if SG can't help you out.
Thanks Crackedback, I will send you a PM. Chad
Thats what I like about this site, everyone willing to help! Thanks again
