Duster Front Seat Repair Options
KOZ45
Indiana
What are some options to fix or replace this front seat?
See attached pics........the single small cut in the back portion doesn't bother me all that bad, but obviously the seat portion on the driver side needs to be fix/repaired
New cover? Able to do this myself?
Just get a generic cover and call it?
I've done a bunch of low and high back buckets myself, always using Legendary Interiors stuff. Not the cheapest way to go....$438.- Ugh. It is very nice quality usually. You could try a local upholstery shop, but the prices locally around me are more than doing it yourself. If the foam underneath is bad, the costs go up of course.
70 DUSTER/DUSTER 340 SPLT BNCH UPHOLSTERY - BLACK | Legendary Auto Interiors
If you'd be happy with a cover for the time being then there you go. There's really no cheapo way to repair it.
$450!!!! Wow.
I might just measure the seat and find a lay over style cover
Couple of black 'high-backs' and console setup would look super on your Duster. Parts are still out there but not always in your vicinity. If you find a good replacement 'split-bench' then consider the matching rear seat. One or two of our benevolent members should be able to step up to help.
