[WANTED] Dutra duals slant six 225
Slantsix64
SSG
Looking for some dutra duals only the first piece casting, if you have a modified stock heat riser that has been cut and welded to accept the front dual i would also be interested thanks
I believe I have a rear casting that's been cut and welded. I'll take a look today.
Here is the front casting I have. I gave it to a friend to weld but braced it instead. So I've got to smooth all that so it looks decent and find a counterweight for the flapper. It's got part of one of the front mounting area broke off (where that stud is) but looks like it will still work and seal OK.
And the front Dutra I have - it's damn near as heavy as the rear casting!
The plan is to use them with an Offy twin single I have.
I was thinking about running another Dutra in the rear instead of the modified manifold but decided to hold off as he gets for each Dutra something like $300 shipped.
I purchased a lot of disc brake parts, in person, from that seller this morning.
A good guy to do business with, so i would give others a very favorable recommendation, on parts purchases.
He's a member on this forum, but i don't know his user id, I didn't ask.
Jim V.
