[FOR SALE] Dynamic 9 1/2" Converter- 904
petegbeeman
los angeles
Hi FABO-
I have for sale a Dynamic 9 1/2" race/street converter(904). Stall is 3500. I went to an 8" for my new combo. This is a used piece. I purchased the converter 4-5 years ago, it has maybe 200-300 street miles and 20-25 passes at the track, where it went a best of 7.01(1/8th). My starter worked loose and chewed up some teeth, so I sent the converter to Jeff at Dice Converters here in Los Angeles. Jeff went through, inspected/cleaned, installed a new ring gear and cover. Never re-installed and zero miles since the freshen up(picked it up today, 12/3/20). Questions/more pics, please let me know.
$500 OBO, plus shipping, free local pickup- Los Angeles 90039.
Thanks for looking! Pete
Thanks for the question. My motor made 591hp @6600/560tq @5600 on IMM's(Indio Motor Machine) engine dyno. 3,500 is advertised stall per Dynamic. I footbrake, and was only able to hold to roughly 2,000rpm. Can't say where it flashed. 1.53 60'. Hope that info is helpful.
Thanks again, Pete
Can you get the Weight and dimensions of the box you will ship it in please so I can get some shipping quotes?
The box you see in the picture above is 14.5" x 14.5" x 6.5" and weighs 30lbs. I would want to put this box in another, beefier box with some form of packing material for shipping, so the dimensions will be larger, but the weight should be pretty much the same. Shipping from 90039. Hope that is helpful. Please let me know if you have more questions.
Thanks, Pete
Next in line.
Thanks Tbro. I will add a FABO member reached out via PM at 5:53- 1 minute after Tbro. So if a line forms, I guess said member will be 3rd in line? Not sure the protocol, just want to be fair and keep things straight. I appreciate the interest.
Pete
