Dynamic comp on 390
Small Block Mopar Engine
  1. OLFOOL
    OLFOOL OLFOOL
    13
    25
    Jul 27, 2021
    New South Wales, Australia
    Local Time:
    10:27 AM
    Just wondering if anyone could work out the dynamic comp on the 318 stroker we are about to build using a Comp Cams Xtreme Energy 242/248 Hydraulic Roller I normally use the UEM calculator but it asks for inlet ABDC @.050" and the roller is at .006". Any help appreciated.
  2. rumblefish360
    rumblefish360 So close, yet so far away FABO Gold Member
    41,594
    13155
    Jun 21, 2005
    New York, on a Island
    Local Time:
    8:27 PM
    Comps web site should have all of that information for you. They post the cam card on there site when you look up the cam itself.
  3. OLFOOL
    OLFOOL OLFOOL
    13
    25
    Jul 27, 2021
    Local Time:
    10:27 AM
    not @ 050" only at .006" as I posted.
  4. Max1196
    Max1196 Well-Known Member
    988
    720
    May 12, 2016
    Swift Current SK
    Local Time:
    6:27 PM
    Use the Wallace Calculator. My ASSumptions include an elavation of 366 feet.
    Camshaft, Rod Length, Boost and Altitude Correction to Compression
    Static compression ratio of 11.7:1.
    Effective stroke is 2.92 inches.
    Your dynamic compression ratio is 8.81:1 .
    Your dynamic cranking pressure is 183.51
    PSI.
    Your effective boost compression ratio, reflecting static c.r., cam timing, altitude, and boost of 0
    PSI is 8.74 :1.
    V/P (Volume to Pressure Index) is 157.
    Edit , I see Comp Cams aren't being clear on their timing figures on the cam card. Those #'s are not at .006 there at .050 on their illustration.
    Is there not a "value" given for piston valve reliefs?
  5. rumblefish360
    41,594
    13155
    Jun 21, 2005
    Local Time:
    8:27 PM
    Sorry, my bad. Thought I read different.
    The advertised numbers are 292/300 but at what exact lift point Comp uses for that XE Hyd roller shaft is IDK. You could try those numbers. I’m not 100% on this, but *I Think* Comp uses the .006 on there other cams along the similar lines. As in not there race cams.
    Xtreme Energy 242/248 Hydraulic Roller Cam for Chrysler 273-360
    I see your location. Perhaps a phone call would work? I know the time difference is huge.
  6. mopowers
    mopowers Well-Known Member
    5,826
    2933
    Feb 15, 2006
    West Sacramento, CA
    Local Time:
    5:27 PM
    I don't get the numbers they post on their site. The intake timing events at .006" lift are shown, but actually add up to their duration at .050" (15+180+47 = 242*). I'm guessing it must be a misprint and those are actually the events are .050"??
  7. rumblefish360
    41,594
    13155
    Jun 21, 2005
    Local Time:
    8:27 PM
    I initially started to write what you have discovered but decided to bite my counts and figured a call to Comp would clear things up faster and more accurately since it’s there cam and web site. LMAO!
    Expert time!
    • Like Like x 1
    • 33IMP
      33IMP Well-Known Member
      1,508
      1552
      Jul 3, 2020
      Taxifornia, soon 2b arizona
      Local Time:
      5:27 PM
      Are you trying to get compression ratio, or DYNAMIC comp ratio? Two very different numbers and calculations!
