E Brake question
FlDart360
FL ,Zero Elevation
Does anyone know if it’s ok to drive your car if you have your emergency brake cable disconnected. 8.25 rear with 10 inch drum brakes. This is only until I get some new parts, just didn’t know if I should sideline the car completely.
Inner cable disconnected/relaxed= OK. A spring at the rear backing plate will return the cable to it's unused position, out of the way.
