[WANTED] Early A 4 Speed Parts
64Bones
Los Angeles CA
Rating - 0%
0   0   0
I'm looking for early-a clutch and brake pedal assembly, early linkage/ z bar with connecting rod, clutch fork, and cast iron slant six bell housing.
Parts are needed for a 64 Valiant.
-Bones
I'll check tommorow as I believe I have a pedal assy
I have the pedals if you still need them but need to look under the car to see if everything else is there. From a 63 Valiant.
Here are some early A shaft, "Zbars" I have. The bellhousing bracket ball stud is a 6 cyl one, They are different than V8.
-Bones
i have the pedal assembly
