Early A body 360 Radiator
Valiant Ef4t
Member
Portland, OR
What will work using the 360 water pump? I do not have a 65-66 V8 radiator for changing inlet location, and hoped something later via wrecking may work.
First thing we need to know is what make and year do you have? Once we know that there is a few different ways to go.
Mike
A 22 inch radiator from a 70 and up V8 should fit pretty good and the lower hose location should be OK for a stock 70-up water pump. You should be able to find an upper hose that fits as well. When installing it, you might have to re-drill a mounting hole or 2. You also might consider one of the Champion aluminum radiators. A member here is a distributor.
