Early A Body bucket seat backs
Early A-Body Discussions
  1. wheelsport
    wheelsport Well-Known Member
    132
    81
    Jan 21, 2019
    Vancouver, Washington
    Local Time:
    1:37 PM
    The early A body car bucket seats have the habit, of the seat back flying forward on a quick stop. Has anyone attempted to cure this problem without replacing the seat with a non-stock seat?
    • Agree Agree x 1
    • cudamark
      cudamark FABO Gold Member FABO Gold Member
      8,921
      1416
      Mar 14, 2009
      San Diego
      Local Time:
      1:37 PM
      No, I just try to leave a lot more stopping distance so I don't have to slam on the brakes! :steering::lol:
    • wheelsport
      132
      81
      Jan 21, 2019
      Local Time:
      1:37 PM
      That's not always possible.
    • cudamark
      8,921
      1416
      Mar 14, 2009
      San Diego
      Local Time:
      1:37 PM
      I can't imaging it happening enough to where I would want/need to modify my seats.
      • Agree Agree x 1
      • RedFish
        RedFish Well-Known Member
        25,280
        3619
        Sep 5, 2007
        Local Time:
        3:37 PM
        • Like Like x 1
        • toolmanmike
          toolmanmike Moderator Staff Member FABO Gold Member
          61,241
          49706
          Jan 18, 2006
          Iowa
          Local Time:
          3:37 PM
          You would have to add in a latch. My 66 buckets doen't have a latch but my 70 bench does. Get inventive!
        • valiantpatrol
          valiantpatrol FABO Gold Member FABO Gold Member
          1,144
          209
          Apr 21, 2009
          Tucson, AZ
          Local Time:
          2:37 PM
          There is actually a spring on the inside hinge to prevent this but they wear? out. If there, you can stretch them a bit back to their original shape/length. Almost every upholstery shop I've been to over the years loses them when redoing the seats. You have to remove the seat back from the base and look down inside the pivot/hinge area to see if your spring is still there.
          • Like Like x 1
          • wheelsport
            132
            81
            Jan 21, 2019
            Local Time:
            1:37 PM
            Is the spring in the seat bottom or the back? What does it look like so it might be replaced?
          • toolmanmike
            61,241
            49706
            Jan 18, 2006
            Iowa
            Local Time:
            3:37 PM
            I haven't physically taken my 66 buckets apart but pulling them out for upholstery and such, there is no lock mechanism there. I haven't paid close attention to 67-8-9 seats to see if they have a seat back lock. I know the split backs on my 70 bench seat has a lock/lever.
          • valiantpatrol
            1,144
            209
            Apr 21, 2009
            Tucson, AZ
            Local Time:
            2:37 PM
            Agree with toolmanmike that '66-'67 seats did not come with them. '62-'65 passenger seats did. Attached is a pic of one. It sits down in the recess of the seat back pivot tabs on the seat base. The top of pic is the top of the part installed. The tip of the seat back mounting flange/pivot arm rests in the dip and had to overcome the spring tension/high spot behind the dip to flip forward. Willing to lend part to vendor interested in remaking them. Same "spring" is used in all "A", "B", and ""C" body buckets for years specified earlier.
            • Like Like x 3
