[SOLD] Early A body V8 engine mounts
Moparbrad
You don’t know me
Phoenix,AZ
Rating - 97%
32   1   0
These are from a 65 273 Barracuda. Good condition other than some grease build up.
$75 shipped in the US
I could use them. Got a 5.9 going in a 64 dart where a slant was. Work for that you figure?
Guess I’m Mr. Mopar. Yes, they will work on a 5.9 360. You will need to make a spacer on the driver side between the mount and block boss. 340 and 360 have a little narrower mounting boss spread. Way cheaper than buying an aftermarket mount set.
These "bricks" lift the motor off the K more so than the "ice cream sandwich" style.
I see now, those are quite a bit thicker than the other ones. If nothing else, it should give me a little more room for the headers, yes?
