[Found!] Early A clutch parts needed
SGBARRACUDA
ROY
Legendary Member
PLANT CITY FL.
I’m helping a friend and another member rebuild/restore some clutch pedals and parts.
I need a clutch pedal over center spring. A master cylinder push rod. I need a V8 bell crank ( this one is Mickey moused beyond belief) I need the bell crank ball on the bell housing side. I need two sets of the plastic halves that go on the bell crank ball studs. Oh and a brake light switch.
Hey Roy, what's the length on your master cylinder pushrod? I think I have one squirreled away somewhere on Parts Mountain.
I think that rod is usable. I had to straighten this one out. I’ll measure this one tomorrow and get back to you to compare them. Thanks.
Measure the over all length of the brake push rod. I’ll measure this one. I’ll get a hold of 1badcolt , Chris and get him to get in touch on the other stuff Thanks
Ok thank you Sir
Roy will get it all worked out he is restoring pedal assembly
Im not knowledgeable about the assembly in general sorry
Roy said basically the entire assembly was used up poor shape etc.
