Early A disc brake swap
Mr.Furious
Active Member
Capitol city
Would there be a problem using 73-76 A-body upper control arms and 78 dodge magnum brake spindles and rotors on a 66 dart ? I want to go large bolt pattern.
I would hold out for the 73 up "A" body spindles, better geometry. But you can use the calipers caliper brackets, Rotors and sheilds off the Magnum. I'd get everything I could off the Magnum. Rear brakes, Master cylinder, Proportioning valve. You would need 15" wheels to use the 11.75 disks, I think.
