Early A door lock conversion
About making keys work. It might take moving the tumbler pins. I did that 40+ years ago when I had 66 Dart and Barracuda. There are 2 pins and a spring per hole. The lengths of pins vary length by notch in key, combined length same. Top pin rounded, lower is flat. There is cover over pins, that can be pried off and reused. Use egg carton to keep track of order. It helps to have spare cylinders for more range of lengths. Compare key, same notch, no change....swap positions or pins as required.
I imagine you are very good mechanically, and can handle the small parts with ease.
