Up for sale is the floor shift power steering column from my 65 Dart GT. This column has been completely rebuilt with all new parts. After I disassembled it, the tube, collar and turn signal housing were sent to Leanna where she did her magic. She powder coated all three pieces in glossy Ink Black. I bought and installed a brand new turn signal switch assembly from SlantSixDan (he had them repro'd from the original supplier to Chrysler and they are perfect in every sense of the word). I will include a used connector for the wiring. During the re-assembly the upper bearing was cleaned and re-greased. Down at the bottom of the tube I installed a brand new rubber seal with the hard plastic center section to center the steering shaft. The connector that mounts to the steering box is nice and tight with a good seal on the top cover. You'd be hard pressed to duplicate everything - powder coating, new turn signal switch and rubber bottom seal for a price of $400. I will let this go for $200 plus shipping from 22657.
