[SOLD] Early A Map/courtesy Light
65 Dartman
1 of None 65 Dart Sedan Delivery
Strasburg, VA
Here is an early A map light bezel or in a convertible, a courtesy light bezel. It includes a complete, unbroken or not warped lens. There appears to be some black overspray on the inside, which I am not going to attampt to remove nor try and remove the lens, the they are over 50 years old and tend to break/crack when trying to remove them. $60 shipped in the US from 22657; elsewhere actual shipping cost. I accept PayPal (friends and Family please) or add the 3% fee.
Also included is your choice of one of two wiring harnesses. The first one shown has a fairly long red/pink power pigtail that usually plugs into the lighter harness and a long yellow pigtail that usually plugs into the passenger door harness
The 2nd harness has a pretty short pink power pigtail and a longer yellow pigtail that usually goes to the passenger door switch. With the short power pigtail, it appears the light would be mounted in the middle of the dash near the lighter. The other harness could be mounted just about anywhere under the dash
The 2nd harness has a pretty short pink power pigtail and a longer yellow pigtail that usually goes to the passenger door switch. With the short power pigtail, it appears the light would be mounted in the middle of the dash near the lighter. The other harness could be mounted just about anywhere under the dashView attachment 1715784643
For convertible cars and those who ordered the extra!
