Early B body 8 3/4 backing plates, etc
Brakes for your Classic Mopar
  1. geminimotors
    geminimotors Well-Known Member
    391
    302
    Nov 24, 2015
    Oakland
    Local Time:
    11:17 AM
    Soooomeday I’ll need to get my rear end on the BBP train. My pal has a yard full of 63-65 B bodies and parts. Including early 8 3/4 axles with the dreaded gland nut. My question is like so:
    Are the shock plates, backing plates, drums, hardware, etc from the early B body housings compatible with a later 8 3/4 housing and the parking brake cables on my 65 Barracuda? If so this might be my way into horse trading other rusty junk and keeping the cost down.
  2. Darter6
    Darter6 Well-Known Member
    5,143
    2643
    Jan 16, 2008
    Nevada
    Local Time:
    11:17 AM
    No on the backing plates from the early 64-older 8 3/4''.
    Everything else will work (if you remove the drums from the gland nut hubs) you can reuse your park brake cables.
  3. SGBARRACUDA
    SGBARRACUDA ROY FABO Gold Member Legendary Member
    22,011
    10531
    Dec 7, 2006
    PLANT CITY FL.
    Local Time:
    2:17 PM
    The backing plates from a 62-64 B body are suppose to be usable. According to Doctor Diff.
  4. Darter6
    5,143
    2643
    Jan 16, 2008
    Nevada
    Local Time:
    11:17 AM
    Well you can as the bolt pattern is the same but the hole for the bearing is much smaller. You can have it machined or open it yourself by cutting/grinding to the proper size.That way the axle and bearing can pass thru the backing plate.
  5. cudamark
    cudamark Well-Known Member
    9,999
    2039
    Mar 14, 2009
    San Diego
    Local Time:
    11:17 AM
    The shock plates will work if the shock mount pin is close enough to a stock A-body location to use stock shocks. Otherwise you may have to figure out which shocks will have the needed expanded and contracted length specs to use with your model car.
  6. geminimotors
    391
    302
    Nov 24, 2015
    Oakland
    Local Time:
    11:17 AM
    Koolsville. Thanks for all the info. I’ll post a thread if I can get the parts.
