Early Hemi swap into my 1973 scamp??
440scamp
Member
Santa Rosa CA
does anyone know if this swap has been done and how much work is it? any help at all is great.........Thanks the motor is a 354 Hemi
Yes, it has been done. And it looked awesome.
There was a site that a guy dedicated to dropping a 354 into his 67-69 (can't remember which year exactly) Barracuda. The fitment was fine and he felt the 354 was the motor to use.
Of course, a hemi into an A-Body is the ultimate of ultimate's but a 354 weighs 700+ pounds (someone correct me if I'm wrong here), and you could build a 360 that would make equal or more power and have 150+ pounds shaved off the front end (thats with Cast Iron heads too).
Depends upon what you want though; I would like to see you do it, it would be kick ***. I would be very tempted to do it myself if I had a 354 laying around :-D
Good luck,
Tyson
I have installed early Hemi's in different bodys, but not in any A body. The heads are very wide,but the exhaust ports exit down,you will have to hand fabricate headers and steering shaft/u-joints.There are some good trans adapters available,but not cheap,to convert to a-block 727 and it is possible to get a Lakewood scattershield with dual drillings (big &small block patterns) that can be used with spacers to deal with the extra crank length of the early motor. Ambitious swap,but way cool when done.Hemi Al
i hate to say this cause i was gung hoe about putting a 392 early hemi in my 64 dart but once i had the motor and added up all the costs of rebuilding the 392, building a trans to handle the power building the mounts and headers and lots of other misc crap i was going to be like 12,000 into it and honestly for that kinda money you can swap in a 5.7 hemi that would be more reliable make more power and be a whole lot easier to put in
sorry just .02 either way good luck and if you do,do the early hemi i want pics :poke:
I haven't done a 354, but I've got a running 246 hemi, was going to buy a beat A body to put it into. Haven't done that idea yet. But that doesn't mean you shouldn't. DO IT!
I don't think I'd consider doing a Chrysler hemi, but I did think about it when I had my Dodge 325 (smaller and lighter). I sold the hemi to help fund my Barracuda convertible and will be dropping a 440 into it just because it's so easy to do.
