Easiest cheapest way to fix dent
Mopar Body and Trim
  1. Chryslerkid
    Chryslerkid Well-Known Member
    448
    40
    Mar 30, 2012
    Berkeley
    Local Time:
    6:26 PM
    I am trying to fix a small dent... well multiple small dents on the cheap. Example below. My plan is to use the original faded paint on the barracuda as the primer coat sand with some fine grit and do some minor bondo work on door dings ect. Then I plan on spray painting with rattle cans with a 2X rustoleum paint primer and paint included. I am choosing a brighter color close to a B3 blue. My question is what are some simple steps to make sure bondo sticks to these small dents/dings?
    • Like Like x 1
    • Dicer
      Dicer Diceman FABO Gold Member
      1,095
      1445
      Jan 12, 2016
      Land of Lincoln
      Local Time:
      6:26 PM
      Cheap.......180 grit sandpaper sand the dent and around the area maybe 1/2" or so...throw the bondo on....and hope it doesn't pop off in about 6 months time, or when the hood gets slammed shut.
      Cheap+.....180 grit sandpaper sand the dent and around the area maybe 1/2" or so, tiger hair bondo sand smooth then your clay type bondo repeat until your happy...…;>}
      Fast Good Cheap
    • Bodyperson
      Bodyperson Pedal to the metal
      4,939
      6447
      Nov 26, 2015
      NW MONTANA
      Local Time:
      5:26 PM
      Metal finish would be cheapest. :poke:
      • Like Like x 1
      • Agree Agree x 1
      • Fred Scigliano
        Fred Scigliano Lots of money
        13,823
        17777
        Nov 26, 2017
        NORTH DAKOTA
        Local Time:
        6:26 PM
        180 grit is as fine as I would go but if you can get behind the panel and try to push the dent out as much as you can that would be the best.
        If you are not using a etch primer on bare metal than I would sand the paint and try not to hit bare metal then use bondo, glazing putty would be best as it sticks better to a finer sand paper.
        Are you planing on painting the entire car with rattle cans?
      • Bodyperson
        4,939
        6447
        Nov 26, 2015
        NW MONTANA
        Local Time:
        5:26 PM
        Tooth. Plastic filler likes tooth. Its a mechanical bond. #24-#36 grit. Clean. Plastic filler likes clean. After grinding, blow off and clean with virgin lacquer thinner and a lint free rag.
        Now realize, if you drop "bondo" on a dirty concrete you will most likly need a hammer to remove it.
        • Agree Agree x 1
        • Bodyperson
          4,939
          6447
          Nov 26, 2015
          NW MONTANA
          Local Time:
          5:26 PM
        • gdrill
          gdrill OK, now what??? Staff Member FABO Gold Member
          7,254
          7714
          Sep 26, 2011
          Just North of Montana
          Local Time:
          5:26 PM
          A good job won't be cheap. A cheap job won't be fast. A fast job won't be good.
          Or something like that!
          • Agree Agree x 5
          • Like Like x 4
          • RustyRatRod
            RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
            60,904
            32623
            Jun 7, 2010
            Georgia
            Local Time:
            7:26 PM
            Leave it alone. That's the cheapest and easiest.
            • Agree Agree x 7
            • Like Like x 6
            • Bodyperson
              4,939
              6447
              Nov 26, 2015
              NW MONTANA
              Local Time:
              5:26 PM
              Ya, something like that. LOL
            • gregpurcell
              gregpurcell Greg Purcell
              2,072
              180
              Aug 21, 2008
              Near Savannah, GA
              Local Time:
              6:26 PM
              What about threading a self tapping screw into the middle of the dent and GENTLY prying it up with a claw hammer? Be careful not to pull the raised area above the "level" line, then bondo the dent. I think Bondo REALLY likes holes to seat into!
              • Thanks! Thanks! x 1
              • Bodyperson
                4,939
                6447
                Nov 26, 2015
                NW MONTANA
                Local Time:
                5:26 PM
                Dang Greg, you are the shit. :lol:
              • Chryslerkid
                448
                40
                Mar 30, 2012
                Berkeley
                Local Time:
                6:26 PM
                I appreciate all the advice! I am doing this on the cheap. I am not a body paint guy. Yes, I am spray painting the entire car with spray cans. And no, I am not investing hundreds or thousands of dollars in this project. I just want a ten footer paint job that I will not worry about scratching when I burn the tires off the car. Lol. I’ll do my best and post pictures as things progress. As I said I am doing this on a budget and a timeline. Kids wife work= no time. And I have decided not to drop thousands on a professional paint job that will deter me into never driving the thing.
                • Like Like x 1
                • j par
                  j par Well-hung Member
                  22,927
                  11529
                  Jul 2, 2014
                  Portland Oregon
                  Local Time:
                  4:26 PM
                  You'll probably find you'll create more damage that you'll be upset about when the day comes and you can afford a paint job and you want to make it nice and you'll wish you wouldn't have done that cheesy crap.
                  I guess what I'm trying to say is if you're nit picking about those little dents and bondoing it and rattle canning it ain't going to make you happier.
                  • Agree Agree x 7
                  • Like Like x 2
                  • Chryslerkid
                    448
                    40
                    Mar 30, 2012
                    Berkeley
                    Local Time:
                    6:26 PM
                    Thank you for your wisdom. I will none the less move forward with my plan. I’ll let you know when you’re correct in your statements above. Lol.
                    • Thanks! Thanks! x 2
                    • Chryslerkid
                      448
                      40
                      Mar 30, 2012
                      Berkeley
                      Local Time:
                      6:26 PM
                      I’m sure many of you as stated in the above comments are rolling around in your graves because you have many years of experience in auto body work and therefore know the “right way of doing the job”. I am going to have to learn the hard way gents. I’ll still let you know how things turn out. If after all is said and done, it is a crap job, I’ll have to look in the mirror and blame myself. Thank you for the advice.
                    • fishmens67
                      fishmens67 Well-Known Member
                      7,698
                      5140
                      Nov 10, 2012
                      idaho
                      Local Time:
                      6:26 PM
                      A dolly and a pick hammer is what I would use. work the metal and finish with a skim coat of mud.
                      • Agree Agree x 9
                      • Bodyperson
                        4,939
                        6447
                        Nov 26, 2015
                        NW MONTANA
                        Local Time:
                        5:26 PM
                        Years of body repair has taken its toll. We aint exactly dead.
                      • harrisonm
                        harrisonm Well-Known Member
                        2,595
                        2425
                        Jan 16, 2005
                        Topeka, KS
                        Local Time:
                        12:26 AM
                        I think you will regret a quicky spray bomb paint job with shaky body work. Buy a book on body work and do it a little at a time, but do it right. When it is time to spray, then figure out what to do.
                      • j par
                        22,927
                        11529
                        Jul 2, 2014
                        Portland Oregon
                        Local Time:
                        4:26 PM
                        I applaud you plowing ahead cuz that's what I did. Damn it! LOL
                        No matter what these idiots at out here LOL
                        I almost got most of that off now....
                      • el5dart
                        el5dart Well-Known Member
                        313
                        208
                        May 16, 2018
                        memphis, tn.
                        Local Time:
                        6:26 PM
                        go to one of those dent wizard places whatever their name is. its easy just reach in pocket to pay when its fixed. i would take grilles and panel off and finness it from the backside personally
                        or eastwood has this Eastwood Paintless Dent Repair and Removal Kit
                        • Agree Agree x 3
                        • rustycowll69
                          rustycowll69 Well-Known Member
                          2,206
                          1001
                          Feb 19, 2016
                          Pacific northwest
                          Local Time:
                          4:26 PM
                          I don't know what those paintless dent repair guys get, but some of the repairs I've seen online are pretty amazing. I would think fixing dents like in your picture, would be child's play for most of those guys.
                          • Like Like x 1
                          • Agree Agree x 1
                          • dirty white boy
                            dirty white boy 47 yr old Juvenal delinquent
                            1,154
                            559
                            Dec 15, 2012
                            stoneville n.c.
                            Local Time:
                            6:26 PM
                            ...........all im saying!!
                            • Like Like x 2
                            • MomsDuster
                              MomsDuster FABO Gold Member FABO Gold Member
                              4,065
                              3842
                              Apr 17, 2016
                              Vacaville Ca
                              Local Time:
                              4:26 PM
                              I can’t tell what the rest of the paint/body looks like, but if what your showing is the worst of it, then I say leave it be and use the cash for more tires! Sounds like your going to need’m!
                            • 69 M-CODE CUDA
                              69 M-CODE CUDA Well-Known Member
                              58
                              77
                              Dec 4, 2017
                              Fitchburg, WI
                              Local Time:
                              6:26 PM
                              Good, Fast or Cheap. You only can choose two of the three.
                              A good, fast job won't be cheap.
                              A good, cheap job won't be fast.
                              A fast, cheap job won't be good.
                            • BrianT
                              BrianT Let's go!
                              5,507
                              1231
                              Mar 13, 2007
                              Kansas City, Mo
                              Local Time:
                              6:26 PM
                              I've been with Dent Wizard for 24 years this summer. The process that we use is not conducive to older cars with thick sheet metal. I've been able to fix a few dents here and there over the years, but for the most part my tools bend before the dent does. If you don't believe me come on over and I'll let you look at the dings on my Dart that have been there since I bought it 12 years ago.
                              • Like Like x 4
