71DodgeDemon340
whats the easiest way to check the clutch adjustment on a a-833 with a scattershield? Mine is at the top of the pedal but i believe it is too high, just want to make sure the clutch is fully engaging. Drives fine no slipping but not sure the easiest way to go about it since i cant get a feeler gauge in there, also is there a different adjustment for pedal height vs clutch engagement? Or are they both related. I usually adjust the shift linkages every year but its been awhile since ive messed with the clutch. Any input or advice is appreciated
