Ebay turbo kit for a big block.
There was a member attempting to use those headers and one needed modified. If I recall correctly he didn’t continue on with the project (or at least update the post) it’s in the boosted section.
Back in the day there were some guys attempting remote mounted turbos. That always seemed to me to be a better idea because the piping would cool your air charge and exhaust acting like an intercooler.
Just an idea but turbos would fit nicely under the back seat area
worst thing there is oil feed and return for the turbo. bare minimum is a pump near the turbo to return the oil to the engine. best solution is seperate oil tank, pump and cooler etc just for the turbo.
neil.
neil.
Not back in the day. Lots of guys still do it. Including myself. The length of pipe absolutely does NOT act like an intercooler and a separate oil system for the turbo is a pain in the ***. I just run an Exa pump, Exa-Pump is #1 Worldwide
at the turbo and plumb it right back to the engine. @Turbo440Dart Is correct a guy tried those headers and one side needed a spacer and the other side needed on tube cut and modified. That’s where it ended. He’s doing body work first.
eBay turbo headers
