Edelbrock 0780 9636A Rebuild Kit
Fuel and Air Systems
  1. Robbie2734
    Robbie2734 Lambcharger
    1,652
    107
    Aug 6, 2005
    Milford NJ
    Local Time:
    2:47 PM
    I need to rebuild my AFB, it's been done once and the accelerator pump only puts out a weak stream. Who makes a good rebuild kit??
  2. RustyRatRod
    RustyRatRod 30 Degrees Outta Whack FABO Gold Member
    47,999
    13385
    Jun 7, 2010
    Georgia
    Local Time:
    2:47 PM
    Walker. You can get it from your local O'Reilly. But 9636 isn't an Edelbrock number. That's a Carter Competition 625 CFM AFB carburetor.
  3. Robbie2734
    1,652
    107
    Aug 6, 2005
    Milford NJ
    Local Time:
    2:47 PM
    Thanks Rusty, I'll check them tomorrow.
  4. RustyRatRod
    47,999
    13385
    Jun 7, 2010
    Georgia
    Local Time:
    2:47 PM
    If you have any trouble, ask them to call the Springfield tech line and give them that carburetor number. They will have a Walker kit number in a few seconds.
  5. Robbie2734
    1,652
    107
    Aug 6, 2005
    Milford NJ
    Local Time:
    2:47 PM
    It's all back together now, I had a few problems. I found the Accelerator pump problem right away, it has a weighted needle valve. The one in there was too long and wouldn't let it open. The second was none of the gaskets for the venturis bases matched the old ones.. The ones from Walker almost fit, I couldn't get it to run right til I reused the old ones. All good now, thanks for the help.
    • Like Like x 1
