[FOR SALE] Edelbrock 1411 750
RustyRatRod
Caput villa stultus
Georgia
Edelbrock 1411 750 electric choke carburetor. I had this on my truck but it was too big so I swapped it out for something smaller. It ran fine, but it was just too big. It is a used carburetor and the price reflects that. No warranty expressed or implied. Simply selling because I don't have anything with a large enough engine to need it. Comes with fuel line and fuel pressure gauge. I am located in middle Georgia.
$175 plus shipping to the lower 48.
Can you check if it fits in a USPS large flat rate box? If yes, I am interested. Shipping to 96817. Thanks
I don't have to check. It will fit. These will fit in a medium flat rat box, but I prefer the large because there is more room for packing. Some of the sides of the carburetor are right up against the side of the box in a medium box and are more subject to damage. Now, it will be a little more than the large flat rate price, because I add the amount of insurance same as the purchase price. They only come with 50 dollars. That's not enough to cover your purchase. It doesn't add much more to the total price at all. Shipping will be whatever the large flat rate is, plus a tad more for the added insurance.
Do you think this would be too big for a 360?
Refresh my memory about your build. It will probably be about right. It was to big for my engine, because mine is box stock, right down to exhaust manifolds.
360 .030 over speed pro 116 pistons 9.5 scr lunati 702 cam ( 262 advertised 220 @.50 duration .475 .494 lift) headers and a factory cast iron 340 intake.
Yes, I think it would work fine. That's way more motor than what I have in the truck.
I have a 1850 Holley that needs a rebuild I was kinda wanting a ready to run carb just because I'm really nervous about breaking in a new cam with a carb that i rebuilt.
Well this one runs. I am sure it will be fine for breaking in a cam but you need to understand, it will need to be tuned to your combo once that's done. That's up to and including re-jetting or changing metering rods and or springs. But it will run out of the box.
