looking at an Edelbrock manifold stamped 318/360 will this fit a 1966 273? i know the 273 and 318 manifolds inter change 1966 and up. just trying to figure this out. I need a little help I am afraid the 318/360 ports are a little bigger than i need.
Do t worry about port size. The intake will fit. The 64/65-273 has the odd bolt angle and size.looking at an Edelbrock manifold stamped 318/360 will this fit a 1966 273? i know the 273 and 318 manifolds inter change 1966 and up. just trying to figure this out. I need a little help I am afraid the 318/360 ports are a little bigger than i need.
How about for a 273?those came stock with 318 ports. see if there are grind marks to make them closer to 360. It will bolt on. Good intake for a 318.
Yes it will fit and work fine. If there is any difference in port size don't worry about it. Your 66 273 will never know the difference but it will like the 4 barrel.looking at an Edelbrock manifold stamped 318/360 will this fit a 1966 273? i know the 273 and 318 manifolds inter change 1966 and up. just trying to figure this out. I need a little help I am afraid the 318/360 ports are a little bigger than i need.
According to Chrysler 64 & 65 had the vertical mounting bolts. I knew some 273's had it that way but didn't know it was changed for 66.
64 and 65 does. 66 and newer is like all LA small blocksDidn't 273's have vertical mounting bolts like a Hemi? Look at your existing engine manifold and compare mount bolt holes. The 318 & 360 had angled bolt holes.
What a fricking train wreck. I think I will PM the OP and set him straight. LOL You know and I know but there are some that don't and shouldn't comment.Please, show me a picture of this. (LMAO!)
64/65 - 273 with vertical mounting intake bolts like a HEMI.
I just sold a Edelbrock dual plane dual quad for these 64/65 273’s.
Then I’ll post one below....In the Mopar Small block book, P4876826, on page 127 in the head section Introduction paragraph 3 it says 64-65 heads had bolt holes drilled at a different angle. No pictures though.
No it does not....64 and 65 does. 66 and newer is like all LA small blocks
Look below, you can see some of the OE mount lads still semi intact. THIS IS A 64/65 - 273 INTAKE!What a fricking train wreck. I think I will PM the OP and set him straight. LOL You know and I know but there are some that don't and shouldn't comment.
You know what is going on!They are not vertical like a magnum. They are a little more vertical than a 318 but not much. You can mod a performer to fit a 65 odd angle head with a 5/16 drill , just lean it over in the 3/8 hole to match the 65 5/16 bolt angle.
Semantics. No the bolt holes are not vertical but not at a 90° to the intake surface like 66 and newer. I will correct my post by clarifying my answer.Then I’ll post one below....
No it does not....
[SOLD] - Modified D64 to D66
I need a drink! LOL (maybe a Snickers bar)
That’s it, I’m going back working on my POS cylinder head!
I need a cookie.....
I wasn't kidding. LOLI need a drink! LOL (maybe a Snickers bar)
