$ 1,000 OBO - PM ME IF INTERESTED
Located: New York, NY 10002
SHIPPING NOT INCLUDED
I have a set of lightly used Edelbrock 6077 Aluminum heads. I am going in a new direction with another build. The engine they came off of had 8,000 miles before removing. They are box stock with no port work/machining. All threads are in good shape with no pull out of cross threading. The Correct ARP Head Bolts Are Included.
I can deliver to Long Island if needed.
Specs on these heads are as follows:
Combustion Chamber Volume 63.0 cc
Deck Height 9.600 in
Deck Thickness 0.562 in
Exhaust Valve Diameter 1.600 in
Guide Plates Included No
Intake Runner Volume 171.0 cc
Material Aluminum
Push Rod Diameter 0.312 in
Valve Angle 18 deg
Valve Spring Diameter 1.460 in
Valve Spring Maximum Lift 0.575 in
Valve Stem Diameter 0.341 in
Material Aluminum
Valve Angle 18 deg
