Edelbrock Air Gap Model 7576
coalman
Texas
Anyone have one of these on a 360, if so what do you use for the carburetor return spring bracket? Thanks
I ran a 3310 Holley 750 with this set up below. I like the fact it is mounted to the carb. I personally like it alo
I used a Lokar set up. Also a "Help section" universal spring to the OE bracket. A basic after market bolt on return bracket (Mr. Gasket) can also take place of the OE unit.
Good pictures Mike.
I have what ScampMike has on a manual and automatic trans cars. It works very good. It gets placed on the carbs rear bolt/stud and snugged down. There is a small stud to adjust it slightly. Alignment purposes.
