Edelbrock Air Gap
Discussion in 'Small Block Mopar Engine' started by 68 Coronet RT, May 13, 2018.
  1. 68 Coronet RT
    68 Coronet RT 68 GTS # 508 in Registry
    229
    31
    Nov 5, 2015
    Upstate New York
    Local Time:
    2:02 PM
    Anyone have a Air Gap intake that they could measure the depth and length of the cutout of the plenum wall where the carb sits. I wanted to buy the Air Gap but living in a little colder climate the Performer RPM is a better choice, now I would like to modify it like the Air Gap
  2. BigBlockMopar
    BigBlockMopar BigBlockMember
    1,537
    483
    May 1, 2011
    Netherlands
    Local Time:
    8:02 PM
    No cutout on mine.
    Just a straight up divider wall upto the carb flange (which had a good amount of (core) shift which hit the throttle blades and prevented more than half throttle. Nice work mr. Edelbork!).
  3. MoparMike1974
    MoparMike1974 Well-Known Member
    913
    445
    Jun 16, 2017
    Maryland
    Local Time:
    2:02 PM
    I have two. No cutout on one, the other I cant get to at the moment.
  4. rumblefish360
    rumblefish360 so close yet so far away
    33,049
    5152
    Jun 21, 2005
    New York, on a Island
    View My Photos
    Local Time:
    2:02 PM
    You’ll find a better performance gain with a spacer. But if you have the room under the hood.
  5. 72bluNblu
    72bluNblu FABO Gold Member FABO Gold Member
    8,964
    2907
    Nov 28, 2008
    NorCal
    Local Time:
    11:02 AM
    Neither of mine has any cut out. People add them, but they don’t come with them. Or at least they haven’t for awhile.
    I also run mine with a 1” spacer and a drop base air cleaner.
  6. furrystump
    furrystump Well-Known Member
    575
    319
    Nov 13, 2004
    Local Time:
    7:02 PM
    Mine didn’t have it. Install it with out it and try it with a spacer and without. That way you’ll know if wants one or not.
    • Like Like x 1
    • mbaird
      mbaird mbaird FABO Gold Member
      3,932
      1181
      Dec 10, 2005
      boise, Id
      Local Time:
      12:02 PM
      None yet here either...
    • furrystump
      575
      319
      Nov 13, 2004
      Local Time:
      7:02 PM
      Is that for a 273? Magnum?
    • rumblefish360
      33,049
      5152
      Jun 21, 2005
      View My Photos
      Local Time:
      2:02 PM
      That is a small block engine, that one pictured is for the Magnum series engine, 318/360.
    • furrystump
      575
      319
      Nov 13, 2004
      Local Time:
      7:02 PM
      The vertical intake bolts
    • mbaird
      3,932
      1181
      Dec 10, 2005
      boise, Id
      Local Time:
      12:02 PM
      Yep... magnum.
      I just realized I never opened it to look.
    • 68 Coronet RT
      229
      31
      Nov 5, 2015
      Upstate New York
      Local Time:
      2:02 PM
      The number for the Performer RPM for the early 340's is 7176
    • 72SwingerJosh
      72SwingerJosh Well-Known Member
      338
      94
      May 20, 2016
      Pennsylvania
      Local Time:
      2:02 PM
      Pretty sure Edelbrock only puts that notch in the Chevy ones.
    • KnuckleDuster
      KnuckleDuster Well-Known Member
      1,636
      630
      Nov 9, 2005
      Texas
      Local Time:
      2:02 PM
      I just had mine ported, and the porter cut .020 out of mine. I didn't know he was going to. He did all the R&D on the P6 and P7 heads for Penske racing, and ported all their heads that won a NASCAR Championship, so I'm betting he had a reason, and not complaining.
      I have run this intake with and without a 1" spacer, and couldn't feel a difference on the street.
      The only time I ran the spacer at the track I was having unrelated fuel starvation issues, so no good data to compare.
      • Like Like x 1
      • AJ/FormS
        AJ/FormS 367 FormS clone 3.09-1.92-1.40-1.09-.78od 3.55s
        14,861
        4025
        Jan 19, 2014
        South-Central Manitoba,Canada, 900ftelevation
        View My Photos
        Local Time:
        1:02 PM
        I run that AG up here North of the 49th, until mid October...... WithOUT a choke. I am back on the road as soon as the sweeper-trucks have made the rounds; April or May. I have started it on warm February days to go for a quick spin,brrrrrrrr. Buuuutt I have a DP carb, and 185psi cylinder pressure. Not bragging just saying.
      • ir3333
        ir3333 Well-Known Member
        4,219
        656
        Jun 1, 2008
        ontario,canada
        Local Time:
        1:02 PM
        why do you want the notch.It was on some older intakes so you could use the old holley carbs.I don't think you will gain anything.
      • 68 Coronet RT
        229
        31
        Nov 5, 2015
        Upstate New York
        Local Time:
        2:02 PM
        This is true, I called Edelbrock as I wanted some answers before I milled and the Tech told me that Edelbrocks dyno runs with the mopar Airgap didn't show enough gain in HP or torque with the wall notched out so they don't offer it. The Tech did say the best thing I could do is run a half inch laminate spacer to help dissipate the heat, any taller spacer would effect the low end torque. So I'm probably going to leave it as is and run a spacer.
      • Lelo Dart
        Lelo Dart *
        1,324
        321
        Oct 10, 2012
        Knob Noster MO.
        Local Time:
        1:02 PM
        Oh, it's worth something. Seen this?
        • Like Like x 1
        • Thanks! Thanks! x 1
        • 68 Coronet RT
          229
          31
          Nov 5, 2015
          Upstate New York
          Local Time:
          2:02 PM
          I saw this video, unfortunately they are not using a MOPAR. They are using a modified 350 chevy . According to the Edelbrock Tech that I talked to today, Edelbrocks dyno test did not show a substantial increase in HP or Torque on the Mopar intakes like the chevy intakes that's why Edelbrock does not offer the Mopar AirGap with the cut out wall. The tech said I could mill it out if I desired to do so but said not to go any deeper than a 1/8 of a inch.
          • Lelo Dart
            Lelo Dart *
            1,324
            321
            Oct 10, 2012
            Knob Noster MO.
            Local Time:
            1:02 PM
            Intake Manifolds - Chrysler - Big-Block - Performer RPM Series - Edelbrock, LLC.
            Big block. Chevy or Mopar the function and respective design is the same. If I ever have my Air-gap off again I will for sure be milling the divider. Not enough hood clearance for a spacer. The spacer is doing the same thing as milling the divider. Allowing the carb to get signal from both banks of the engine. "The problem is that the dual-plane design limits performance, since each cylinder only gets to benefit from half of the carburetor’s available induction flow. Modern dual-plane intakes resolve this issue with a notch in the plenum divider."
          • rumblefish360
            33,049
            5152
            Jun 21, 2005
            View My Photos
            Local Time:
            2:02 PM
            @ou812 Perhaps you can comment on what you have found with spacers on top of the Edel. RPM? As well as a mild divider if you have done such?
            Thanks.
            Lelo, The spacer adds plenum volume. The nothc doesn't. Thats about the only thing. Build dependent, extra plenum volume may be good.
          • leblanc
            leblanc member 2883
            2,056
            229
            Jun 5, 2006
            Dieppe,NewBrunswick,Can.
            View My Photos
            Local Time:
            3:02 PM
            My 79 360 runs on a RPM air gap no: 7576 and runs like a scalded dog.
            • Like Like x 1
            • ou812
              ou812 Well-Known Member
              1,380
              183
              Jan 15, 2005
              SoCal
              Local Time:
              11:02 AM
              1" open really improves power from about 2500rpm and up...also cleans up the A/F ratios with most carbs....
            • rumblefish360
              33,049
              5152
              Jun 21, 2005
              View My Photos
              Local Time:
              2:02 PM
              Thanks Brian.
            • 68 Coronet RT
              229
              31
              Nov 5, 2015
              Upstate New York
              Local Time:
              2:02 PM
              So is Brian talking about a 1" open spacer or a 1" wall cut out ?
              • Agree Agree x 1
