Edelbrock E-Street vs Performer RPM Heads
Big Block A body Tech
  1. JGC403
    JGC403 Well-Known Member
    1,039
    47
    Nov 22, 2010
    Baileyton, TN
    Local Time:
    5:20 PM
    What is the difference between these heads? On their website they have the exact same specs. Same intake and exhaust port volume, same valve sizes, same valve spring max lift, even the flow numbers are the same.
    So if the port size and heads flow the same how can the say the E-Street is for Idle-5500 rpm and the Performer RPM from 1500-6500 rpm?
    So where did they cut corners to save the $422 for the E-Street over the Performer RPM?
    Aluminum Cylinder Heads - Chrysler - Big-Block - E-Street - Edelbrock, LLC.
    Aluminum Cylinder Heads - Chrysler - Big-Block - Performer RPM - Edelbrock, LLC.
  2. rumblefish360
    rumblefish360 I have escaped the evil Empire State! FABO Gold Member
    42,239
    14402
    Jun 21, 2005
    Florida
    Local Time:
    6:20 PM
    I remember this being discussed somewhere. IIRC, it has cheaper & different valves and a lighter valve spring.
    I am not 100% sure though.
    • Agree Agree x 2
    • EchoSixMike
      EchoSixMike Well-Known Member
      269
      91
      Nov 20, 2013
      Chicago
      Local Time:
      5:20 PM
      IIRC, the big difference was the E street heads have sintered iron valve seat (or other hardened material) vs the RPM heads. Might very well be misremembering things. S/F....Ken M
      • Agree Agree x 3
      • mopower440
        mopower440 Well-Known Member
        797
        141
        Oct 12, 2014
        TN.
        Local Time:
        5:20 PM
        so has anyone here bought a set of E-streets for a big block and used them out of the box with no extra porting? Wondering how much performance was gained over the stock iron heads..
      • famous bob
        famous bob mopar misfit
        19,857
        8858
        Aug 14, 2011
        okla
        Local Time:
        5:20 PM
        Dont know, but have wondered the same thing, not that I`m in the market for any tho.
      • rumblefish360
        42,239
        14402
        Jun 21, 2005
        Florida
        Local Time:
        6:20 PM
        The E street is exactly the same as a RPM head port wise. The “E” (for economy IMO) is due to the different valves, lighter springs and different valve seats.
        Who ever has done a iron to RPM head swap could tell you the performance difference.
        It was an excellent upgrade on my small block.
        • Like Like x 1
        • mopower440
          797
          141
          Oct 12, 2014
          TN.
          Local Time:
          5:20 PM
          could you tell a major difference in power?
        • rumblefish360
          42,239
          14402
          Jun 21, 2005
          Florida
          Local Time:
          6:20 PM
          In my small block?
          Oh freaking hell yea.
          I went from a stock port 2.02/1.60 iron J head to the RPM. Intake was a LD-340, carb a TQ, headers were hooker super comp (1-3/4) slugs at zero deck, 9.9-1 ratio, up 1 point with the head change. Cam, 292/.509. 4spd-4.10 E body Cuda.
          This cam didn’t take advantage of the heads flow ability with that tiny .509 lift. Taking advantage of it later was nice.
        • mopower440
          797
          141
          Oct 12, 2014
          TN.
          Local Time:
          5:20 PM
        • rumblefish360
          42,239
          14402
          Jun 21, 2005
          Florida
          Local Time:
          6:20 PM
        • mopower440
          797
          141
          Oct 12, 2014
          TN.
          Local Time:
          5:20 PM
          well, those all say they use roller lifters only? I will be using a regular hydraulic flat tappet cam. I am looking in the 1300.00 price range and am kinda set on the 84cc E-streets, but just wanna make sure there arent any better flowing heads out there for the money than the E-streets.. Someone mentioned the promaxx and i wasnt sure if they were a good head or not as i havent heard much about them..?
        • rumblefish360
          42,239
          14402
          Jun 21, 2005
          Florida
          Local Time:
          6:20 PM
          Call them and tell them the cam your run. I guess and the spring you want to run and they will install the spring of your choice if you want to make that call or the springs the cam manufacturer wants you to use.
        • Moms68
          Moms68 Member
          10
          15
          Dec 6, 2021
          CT
          Local Time:
          6:20 PM
          Is it true that the big block E- Street heads have straight spark plug openings?
        • PRH
          PRH Well-Known Member
          3,771
          5557
          Dec 14, 2018
          So. Burlington, Vt
          Local Time:
          6:20 PM
          Edelbrock 5093 have straight plugs.
          • Thanks! Thanks! x 1
          • 318willrun
            318willrun Utube channel 318willrun
            18,463
            21508
            Sep 13, 2013
            I'm here
            Local Time:
            5:20 PM
            Is one preferred over the other for exhaust manifold/header fitment? Or is it "the angle plug gives better fire" reason.
          • PRH
            3,771
            5557
            Dec 14, 2018
            So. Burlington, Vt
            Local Time:
            6:20 PM
            It’s both.
            Some headers just aren’t a good fit with angle plug heads........ but angled plugs are “better” for the combustion process.
            • Thanks! Thanks! x 2
            • Muswagon
              Muswagon Well-Known Member
              82
              41
              Jan 20, 2020
              Winnipeg
              Local Time:
              5:20 PM
              I just got a set of E street, you do not need the RPM heads at the higher cost unless you are running a roller cam. Even that part is a bit confusing as they both say good to .600 lift. Mine are for the 440 I am building for my Duster. (5090 heads)
              My cousin has a home based head porting shop, and he did some light work on my heads and the difference is crazy. He has not even corrected the valve job yet and they are already flowing over 300 without having to make the intake runner too big and hurt the low end. I will post another one once he corrects the factory valve job.
              Sorry, I don't know why it attached twice
            • RAMM
              RAMM Well-Known Member
              2,234
              2509
              Nov 22, 2010
              Ontario, Canada
              Local Time:
              6:20 PM
              The Eddy 5090 is probably my favourite go to aluminum head--The 75cc chamber is a real bonus if you can build around it which is easy IMO. J.Rob
              • Like Like x 1
              • Muswagon
                82
                41
                Jan 20, 2020
                Winnipeg
                Local Time:
                5:20 PM
                That is exactly why I chose the 5090 with the smaller chamber. I can build my RV 440 as is and still have decent compression or build it and have 10.50 to 1
                • Like Like x 1
                • DC Dart
                  DC Dart Well-Known Member
                  51
                  21
                  Dec 18, 2019
                  Oregon
                  Local Time:
                  3:20 PM
                  How much port work do the Edelbrock heads need to match the trick flows OOTB. I know it's likely cheaper to buy the trick flows for the given flow advantage. But can these E Street be made to flow like trick flow later on? Within reason I guess. Yeah I know define reason right. LOL
                • PRH
                  3,771
                  5557
                  Dec 14, 2018
                  So. Burlington, Vt
                  Local Time:
                  6:20 PM
                  There will likely be a few differing opinions on this, but I’ll preface my response with........
                  “On my flow bench”.......
                  (And I have performed hundreds of flow tests on BBM heads)
                  -I see 320 +/- cfm from an ootb TF240.
                  I have tested a dozen or so....... all very close to 320cfm.
                  -the highest flowing Ede style head I have tested was a MCH CNC ported Stealth, which actually had the intake runners 12cc’s larger than the TF240..... 252cc. It’s quite a bit of porting.
                  The program MCH uses on the Stealth is the same one they use on the Ede heads.
                  On my bench, that Stealth flowed 315cfm( I tested two cylinders, both flowed 315).
                  - if you’re going to have to rely on paying someone to get the Ede’s into the 320cfm range......buying the TF’s will end being quite a bit cheaper.
                  If you’re a skilled head porter and can do the work yourself........ you’ll end up paying yourself minimum wage to end up at “even money” compared to the TF’s.
                  • Agree Agree x 1
                  • Dartnut
                    Dartnut Don't hate me because i'm beautiful
                    11,875
                    5016
                    Apr 19, 2007
                    Southern Alberta
                    Local Time:
                    4:20 PM
                    What I don't get is why do we have to get the aftermarket heads checked out for valve job, guide fitment, etc. and why are they not ready to bolt on OOTB?
                    Other than changing springs that match your cam, why do they even have to be touched or checked at all?
                    That is something that has always irked me.
                    Is their quality control that piss poor, or do they not even care?
                    They must be just literally slapped together on old misadjusted equipment or by assemblers who don't know or care a lot about their customers.....
                  • PRH
                    3,771
                    5557
                    Dec 14, 2018
                    So. Burlington, Vt
                    Local Time:
                    6:20 PM
                    Nobody is making you have the heads checked out.
                    Just like you don’t “have to” check any clearances when assembling a motor, or degree in your cam.
                    Yesterday I got a text from a builder I do a lot of work for.
                    He had a blown BBC on the dyno and was just giving me a dyno report.
                    That motor got some new Brodix Race Rite heads put on it.
                    They were run basically ootb(inner springs removed for cam break in).
                    I’m sure industry wide there is a fairly high percentage of aftermarket heads that get installed right ootb.
                    Sometimes that ends up successful...... and sometimes not.
                  • 318willrun
                    18,463
                    21508
                    Sep 13, 2013
                    I'm here
                    Local Time:
                    5:20 PM
                    I'm not a huge buyer of aftermarket heads, but I disassembled my Speedmaster small block heads at home and inspected, found nothing, reassembled and no issues. It doesn't get driven a lot, but they've worked fine. So, some may be just fine OOTB
                    • IQ52
                      IQ52 Well-Known Member
                      2,749
                      2552
                      Jul 30, 2011
                      Idaho
                      Local Time:
                      4:20 PM
                      I can state that the E Street/RPM casting, in well ported form, without epoxy or welding can support 780+ horsepower using a 451 stroker and 91 octane pump gas.
                      • Like Like x 1
