j061093409
1970 Dart Swinger 340 Reg
this is ONLY for someone who can weld aluminum!!!!!!!!!!!!!!!!!!
There is 3" crack at the rear of the flat mounting surface. The crack is along the coil reinforcement. the front sending unit hole has a pipe in it and would need to be re-sized if installing a sending unit. the throttle return bracket hole also needs attention. Looks like the metal roll pin was not removed and someone torqued it down. This needs work. just asking $65.00 + ride obo
dart340@att.net or 860-416-8434
