Edelbrock Performer hole block offs...
Judge Mills
1971 Plymouth Duster
Westport, Washington
Is there a list out there with the various sizes of blockoffs or bolts or whatever you want to call them needed for the edelbrock performer intake? this is on a 318.....
The intake has all those holes for various water passages and things that I don't use.
My buddy just used various bolts around the garage to block his off, and they look ugly....
Any help is appreciated :wave:
I believe on my Performer, they were 1/4" and 3/8", I used aluminum reccessed socket plugs from summit.
Just go to the hardware store and buy some cheap brass plugs, they are flat on the top and look pretty decent. I did this on my Performer 318, then painted it all blue, worked nice. You could also get some allen headed plugs, they will sit even lower in the threaded holes. You could try Summit or Jegs but you will spend more for that stuff.
Thats what I did. I actually walked into the hardware store and started screwin in plugs. The crew was amused.
