Edelbrock performer RPM intake...is it right for my engine?
Small Block Mopar Engine
  1. thanson_mopar
    thanson_mopar Well-Known Member
    1,945
    7
    May 9, 2007
    Black Hills, South Dakota
    Local Time:
    5:33 PM
    First I need to know, does the standard RPM intake fit low enough to where I can run my stock air cleaner for my 74 duster 360 and not have any interferance with the hood?
    Second, is it what I am looking for? I want a dual plane intake that matches my engine top end. is the performer rpm a good match? THIS IS A STREET CAR.
    Cam specs:
    Lift: .484
    Duration: 284/291
    Heads have port work, 2.02 intakes ect...
    So does it sound like the RPM is a winner for my engine? Or is there a better alternative?
  2. stroked340
    stroked340 FABO Gold Member FABO Gold Member
    4,538
    1587
    Jun 14, 2014
    mass.
    Local Time:
    6:33 PM
    It'll work just fine..
    • Agree Agree x 2
    • Like Like x 1
    • Disagree Disagree x 1
    • thanson_mopar
      1,945
      7
      May 9, 2007
      Local Time:
      5:33 PM
      Great, easy enough. Thank You
    • rigger3006
      rigger3006 Well-Known Member
      796
      205
      Aug 6, 2013
      bc
      Local Time:
      5:33 PM
      i have the 284/484 mp cam, went from ld340 to performer rpm airgap,woke it right up
      • Thanks! Thanks! x 1
      • MOPAROFFICIAL
        MOPAROFFICIAL FABO Gold Member FABO Gold Member
        9,474
        8823
        Jun 1, 2016
        Oceanside ca.
        Local Time:
        3:33 PM
        Put a 7 1/6 -1/2 open spacer on the LD340 and you won't be thinking about an rpm version anymore.
        The runner shape difference has minimal effect, i actually like the velocity of the LD , plenum size and the divider opened is where magical difference is more so.
        • thanson_mopar
          1,945
          7
          May 9, 2007
          Local Time:
          5:33 PM
          A concern of mine is if I can make that fit with a spacer, and still use a stock air cleaner and not have hood clearance issues.
          Edit: sorry, i see you were talking to someone else.
        • rigger3006
          796
          205
          Aug 6, 2013
          bc
          Local Time:
          5:33 PM
          are you talking abut factory snorkel air cleaner?thing about spacers are they work differently on different engine combos.nothing seems to be set in stone. 1'' 4 hole spacer worked better on the aforementioned ld340 intake better than a 1'' open spacer.i havent played with spacers yet on the rpm yet, im still enjoying the new tire frying torque i gained
