Edelbrock Streetmaster 318
Mopar General Discussions
  1. 69 Cuda 440
    69 Cuda 440 Legandary Member Legendary Member
    4,248
    218
    Dec 12, 2012
    Wilton, Connecticut
    Local Time:
    3:48 PM
    Designed by Edelbrock, and first released in 1973.
    First designed for the Small Block Chevrolet {350/160 HP} that
    was found in the Chevrolet K5 Blazer.
    * Profile > Single-Plane Low-Rise Intake
    * Style > Short-length runners with narrow passages
    Edlelbrock Engineers {Research and Development} came up with this Manifold, primarily to help fuel mileage and efficiency for small block engines.
    The goal >
    * To provide for better vehicle responsiveness on the low-end.
    * To allow for a more uniform fuel distribution.
    * Better cylinder filling.
    * Reduce emissions at lower RPM's.
    * Increase fuel mileage.
    The small runners increased velocity at low Rpm's, which helped improve efficiency.
    There was better fuel atomization which helped fill the cylinders
    quicker.
    Edelbrock announced that this Manifold improved fuel mileage by
    9% to 14% in economy driving.
    It was accurately marketed, as a 'Mileage/Performance' Intake Manifold, that improved economy for daily driving habits.
    Marketed for >
    * Daily Drivers
    * Motor Homes
    * Pick-Up Trucks
    * Campers
    * Vans
    * Station Wagons
    A true 'Off-Idle to Cruising-RPM' Intake Manifold.
    Awarded the 'Best New Product' at the 1973 SEMA Trade Show
    http://i.ebayimg.com/00/s/MTAyNFg3Njc=/z/wCEAAOSw0vBUkOOl/$_57.JPG
  2. Coronet 500
    Coronet 500 Well-Known Member
    433
    90
    Dec 24, 2011
    Ontario Canada
    Local Time:
    3:48 PM
    I have one and wondered if it would be good for a mild 10-15 lb 318 turbo build I might do.
    Any thoughts on that fellas.
  3. 69 Cuda 440
    4,248
    218
    Dec 12, 2012
    Wilton, Connecticut
    Local Time:
    3:48 PM
    The Edelbrock Streetmaster #3275 is a decent functional Intake Manifold for a
    mild 318.
    Primarily designed for > Off-Idle to 4500 RPM's.
    Once you get above 4500 RPM's, it does fall flat though.
    • Like Like x 1
    • Coronet 500
      433
      90
      Dec 24, 2011
      Ontario Canada
      Local Time:
      3:48 PM
      Yes, I talked my son out of it and into a Torker I have for his hot rod 318.
      It's just one I've got and wondered if the pressure would over come that as the only other ones I have are an SP2P or Holley Strip Dominator in aluminum.
      Just wonderin' out loud.
    • 69 Cuda 440
      4,248
      218
      Dec 12, 2012
      Wilton, Connecticut
      Local Time:
      3:48 PM
      #3025 ....... Small-Block Chevrolet 'Square-Bore'
      #3225 ....... Small-Block Chevrolet 'Spread-Bore'
      #3140 ....... Big-Block Chevrolet {Oval Port} 'Spread-Bore'
      #3275 ....... Small Block Chrysler {Small Port} 'Square-Bore'
      #3110 ....... Big Block Chrysler {361-383-400} 'Spread-Bore'
      #3115 ....... Big Block Chrysler {413-426-440} 'Spread-Bore'
      #3255 ....... Ford 289-302 'Square-Bore'
      #3260 ....... Ford 351 Windsor 'Square-Bore'
      #3170 ....... Ford 351M-400 'Square-Bore'
      #3205 ....... Ford 390 FE {352-390-428} 'Square-Bore'
    • 318willrun
      318willrun Utube channel 318willrun
      15,468
      16582
      Sep 13, 2013
      I'm here
      Local Time:
      2:48 PM
      I bought the Weiand Action Plus. Gobs of low end, as it is designed for off idle, and will pull to 6 grand with a mild cam and headers, especially if its feeding the likes of a 2.02 x head. Will accept spread bore or square bore, and that's a big ++++! Advertised, though, to make power from idle - 5500.
    • rumblefish360
      rumblefish360 So close, yet so far away FABO Gold Member
      39,012
      10587
      Jun 21, 2005
      New York, on a Island
      Local Time:
      3:48 PM
      Pressure on the engine? Go with the single plane Torker or Strip Dom. No doubt, ether one.
    • Darter6
      Darter6 Well-Known Member
      4,189
      1481
      Jan 16, 2008
      Nevada
      Local Time:
      12:48 PM
      Looking at that streetmaster, it kinda gives the impression of the early 273 2 bbl single plane.(Chrysler musta been up to something)I have no comment either way, but always thought that a dual plane was better for bottom and mid range. That statement is kinda of a question. Any thoughts ?
    • Coronet 500
      433
      90
      Dec 24, 2011
      Ontario Canada
      Local Time:
      3:48 PM
      Yes, pressure from the turbocharger.
    • 69 Cuda 440
      4,248
      218
      Dec 12, 2012
      Wilton, Connecticut
      Local Time:
      3:48 PM
      Edelbrock 'Streetmaster 318' {#3275}
      * Square-Bore Mounting Base
      * Narrow Port Passages
      * Short-Runners
      * Helps increase 'low-end' responsiveness
      * Good for 'Off-Idle' to 'Cruising Range'
    • scatpacknorth
      scatpacknorth Well-Known Member
      105
      63
      Dec 16, 2008
      kamloops bc canada
      Local Time:
      12:48 PM
      question --my car currently has a streetmaster, but i also have a ld4b I was thinking about replacing it with.....could I expect any improvement?
      in other words streetmaster or ld4b? i have a mild 318 mild 318,727and 355s
      anybody?
      thanks bruceO:)
    • 69 Cuda 440
      4,248
      218
      Dec 12, 2012
      Wilton, Connecticut
      Local Time:
      3:48 PM
      Scat-Pack-North
      Before you change Intakes.
      What Carburetor are you running with now ?
      Paul
    • sireland67
      sireland67 FABO Gold Member FABO Gold Member
      9,287
      3476
      Oct 27, 2010
      WV
      Local Time:
      3:48 PM
      I would just leave the ld4b on it, its a pretty good intake for your combo.
    • Lelo Dart
      Lelo Dart * FABO Gold Member
      1,475
      434
      Oct 10, 2012
      Knob Noster MO.
      Local Time:
      2:48 PM
      LD4B!!!! :burnout:
    • scatpacknorth
      105
      63
      Dec 16, 2008
      kamloops bc canada
      Local Time:
      12:48 PM
      69 cuda 340----im using an edelbrock 625 cfm
      thx,bruce
    • MagicMan
      MagicMan Well-Known Member
      120
      9
      Jul 8, 2013
      SE Ohio
      Local Time:
      2:48 PM
      I have one of these intakes, been trying to find a 500cfm 4 barrel to run it on my 273 daily driver. Throttle blades on a 600 won't clear unless I run a spacer which I am afraid will affect the purpose and design of the intake.
    • 69 Cuda 440
      4,248
      218
      Dec 12, 2012
      Wilton, Connecticut
      Local Time:
      3:48 PM
      Exactly,
      The smaller sized 'plenum' on the 'Streetmaster 318' is designed for that purpose,
      a smaller CFM-rated Carburetor.
      The early Carter AFB's {Advertised @ 500 CFMs'} off the 273 Commando have.
      * Primary ....... 1 7/16" {1.437"}
      * Secondary ... 1 9/16" {1.562"}
      A too big Carburetor on the 'Streetmaster 318' defeats the intent {purpose} of the
      low-rise single-plane Manifold.
      I have used an older Holley 550 CFM {1 9/16" x 1 9/16" Throttle-Bores} with the
      'Streetmaster 318', and it works like 'A Charm'.
