Edelbrock Victor #77929 Installed Height
SS Lancer
North Carolina
Hello, Gents I purchased above heads with valves and was curious if anyone knows installed height in heads for out box set-up , will set up for 560 + lift Hyd Roller .
Wow, hard to answer as they don't come with retainers, locks or spring locators.
I have found that if you use a .060" locator, a Comp 741 retainer and Comp 611 valve lock.......the valve spring installed height is approximately 1.88". Yes, you must use a locator between the spring and the valve pocket.
You must measure these things for yourself. To take this information as fact and run with it is foolish!
"You must measure these things for yourself. To take this information as fact and run with it is foolish! "
x2.
