1. JoeSBP
    JoeSBP RLTW!
    1,154
    579
    Jun 16, 2015
    NC
    Local Time:
    12:40 PM
    Looking for suggestions for fuel filters..
    running the FiTech FCC so I need a low pressure pre filter, and a hi pressure filter.
    What's the good, the bad, and the ugly?
  2. dgibby
    dgibby Well-Known Member
    954
    355
    Aug 23, 2012
    utah
    Local Time:
    10:40 AM
    Wouldn't you just use a standard fram or wix between the mechanical pump and the command unit?
    And the command center should have come with a filter for between it and the throttle body? or you can order it from them.
    Billet Fuel Filter -Part No: #80112
  3. JoeSBP
    JoeSBP RLTW!
    1,154
    579
    Jun 16, 2015
    NC
    Local Time:
    12:40 PM
    it's been said the supplied FiTech filter is subpar and passes particles larger than the injectors can pass. Some of them even having the flow direction stamped backwards, I'd rather go to something better than gamble with issues.
    as for the standard fram or wix, what PNs?
  4. dgibby
    954
    355
    Aug 23, 2012
    utah
    Local Time:
    10:40 AM
    Wix 33270
    Napa 3270
    You should be able to cross reference them for other options
  5. MoparDan440
    MoparDan440 New Member
    3
    1
    Oct 3, 2010
    Pleasant Grove
    Local Time:
    11:40 AM
    The Wix 33270 is a wire mesh 141 micron filter, I would use the 33033 cellulose 20 micron pre-filter
  6. famous bob
    famous bob mopar misfit
    11,808
    3069
    Aug 14, 2011
    okla
    Local Time:
    11:40 AM
    I use two 1/2" INLINE STEEL FILTERS BEHIND THE TANK, OUT OF DUAL 1/2'' PIPE OUTLETS WELDED TO THE BACK LOWER CORNERS OF MY NEW TANK. THEY ARE REDUCED TO 3/8" PIPE, GO THRU 3/8" SHUT OFF VALVES, THRU THE 1/2" BARBED FILTERS, INTO A 3/8" WYE, AND THEN INTO THE BACK OF MY INLINE / RECIRCULATING FUEL PUMP. HAS THE ORIGINAL NEW -08 LINE AS A RETURN TO THE TANK, W/ THE NEW SOCK CUT OFF. WORKS VERY WELL SO FAR. THE FILTER THAT CAME W/ MY F.I. KIT IS UP FRONT W/ THE REG. ON THE INNER FENDER. ( DIS REGARD CAPS) clumsy typer ! The only thing I`d do diff. is put the outlets a little lower. I didn`t take into consideration , the tank does`t hang level in a 68 fastback. All the above pieces are hot-rodded to look racy .
