1. jau126
    jau126 '65 Dart GT 273 904
    136
    67
    Jun 7, 2020
    Salt Lake City, UT
    Local Time:
    10:31 PM
    I know there are some more general discussions on the form with electric choke questions and answers. I am looking for more specific solutions and thoughts from early A owners. I have a '65 Dart with very original wiring so I do not want to hack it up and make it difficult to diagnose later on.
    I have a relay and a inline fuse (10 Amps) to use for the choke but I am looking for a good source to trip the relay (and power source) or alternative solutions that have already been done.
    I have some ideas and thoughts but there is plenty to learn and a lot of prior experience from other remembers that I do not have.
    Thank you
  2. burdar
    burdar Owen's Dad
    1,145
    220
    Aug 15, 2013
    Iowa
    Local Time:
    11:31 PM
    The blue wire that plugs into the inlet side of the ballast is a 12+ source from the ignition switch in the "run" position. This would be the easiest place to get your 12+. You can run a new wire from this location to your electric choke with your inline fuse holder. I don't really thing you need a relay on this small circuit but you can if you want to. Just use your new wire to activate the relay and run a second wire right off the alternator + stud to power the choke.
    • Thanks! Thanks! x 1
    • 67Dart273
      67Dart273 FABO Gold Member FABO Gold Member
      47,972
      15963
      Oct 14, 2010
      Idaho
      Local Time:
      9:31 PM
      There is only one source, period. that is "ignition run" or IGN1, usually dark blue, and comes from the ignition switch
      ^^EDIT^^ I was typing same time LOL
      Also you could use the output of that relay to feed the VR. Often that blue "run" line suffers VOLTAGE DROP in these old girls. This causes OVER charging (overvoltage) because the VR sees lower voltage and ramps up the alternator output
      You could do this with a reversible modification. Unplug the blue wire at the ballast. Use that connector to trigger the relay. Wire the relay load output back to the ballast terminal. Also pull the VR connector off, and wire the relay output over to that. You can do this with push on "flag" terminals and not cut anything.
      Feed the relay power from the "big stud" on the starter relay through a fuse/ breaker.
      • jau126
        136
        67
        Jun 7, 2020
        Salt Lake City, UT
        Local Time:
        10:31 PM
        Just to verify... The ballast is the white thing on the fire wall with the two connection points near the distributor/factory coil location.
        Pain in the butt to verify these things alone with a multi-meter as I have heard you do not want to leave in in the run position without it running.
      • jau126
        136
        67
        Jun 7, 2020
        Salt Lake City, UT
        Local Time:
        10:31 PM
        Also were would you pick up ground? Edelbrock sends such a short ground wire it makes me think the have people attach it to a carb stud. Seems a little strange but an easy way to do it. Seems easy enough to run over to the main battery ground if needed.
      • 67Dart273
        47,972
        15963
        Oct 14, 2010
        Idaho
        Local Time:
        9:31 PM
        Yes the ballast is the white block usually mounted on the firewall. Some wiper motors have a similar one mounted very close or onto the motor so don't confuse the two. If you need to do some voltage checking with the key "on" then unplug either wire off the ballast........this will kill power to the coil and won't burn up the points
        Something like the carb mtg studs are a good ground. The engine block is as good a ground as the battery. After all it carries cranking current, and you are only talking about a few amps
        • burdar
          burdar Owen's Dad
          1,145
          220
          Aug 15, 2013
          Iowa
          Local Time:
          11:31 PM
          I just wired my electric choke last week. I used the carb stud for the ground. It was a PITA getting that ground wire plugged into the electric choke terminal. Talk about a tight fit.
        • Naplm00
          Naplm00 Well-Known Member
          245
          50
          May 20, 2019
          Bay
          Local Time:
          9:31 PM
          i also used what would be the ballast wiring. The slant electric choke does not have a ground wire, it grounds through the case/themo sender.
        • jau126
          136
          67
          Jun 7, 2020
          Salt Lake City, UT
          Local Time:
          10:31 PM
          Thank you for all the replies. I had initially and foolishly put the relay inline before the coil as the trigger. Maybe I read the pins wrong but lost spark when I did that. Took it out of the circuit and spark came back. Hopefully it will be resolved tonight. Not many weeks left of good driving weather in SLC.
        • Naplm00
          245
          50
          May 20, 2019
          Bay
          Local Time:
          9:31 PM
          If you're using the ignition circuit is there really a need for a relay?
        • jau126
          136
          67
          Jun 7, 2020
          Salt Lake City, UT
          Local Time:
          10:31 PM
          IDK? Edelbrock says to not power it from the coil circuit because it drops to 6V after start. So that would have given me the signal and I was planing to take power of the back of the alternator. But the ballast resistor method should work.
        • toolmanmike
          toolmanmike FABO MODERATOR Staff Member FABO Gold Member
          58,305
          45447
          Jan 18, 2006
          Iowa
          Local Time:
          11:31 PM
          Back of the alternator
          The voltage doesn't drop on the 12v. input side. It does on the distributor side.
          • jau126
            136
            67
            Jun 7, 2020
            Salt Lake City, UT
            Local Time:
            10:31 PM
            Are you voting for the relay method and power of the alternator then or just clarifying? Curious about different opinions.
          • toolmanmike
            58,305
            45447
            Jan 18, 2006
            Iowa
            Local Time:
            11:31 PM
            Oops, the "back of the alternator" was there before and didn't mean to post it. The electric choke on my 66 has been wired to the 12v. input side of the ballast for 10 years now without issues.
          • burdar
            burdar Owen's Dad
            1,145
            220
            Aug 15, 2013
            Iowa
            Local Time:
            11:31 PM
            Edelbrock doesn't want you connecting it to the + side of the coil because the coil doesn't see 12v. The + side of the coil runs through the ballast. The input side of the ballast will give you full 12v all the time.(when the key is in the "run" position)
            • Agree Agree x 1
            • Naplm00
              245
              50
              May 20, 2019
              Bay
              Local Time:
              9:31 PM
              Yea this is what I'm thinking and how I have my slant choke wired. Connect it to the feed side of the ballast resistor, it's always 12v and switched so that it's on whenever the key is on. No need for a relay imo
              • Agree Agree x 1
              • jau126
                136
                67
                Jun 7, 2020
                Salt Lake City, UT
                Local Time:
                10:31 PM
                Just a young mechanical engineer trying to a little extra. Makes my life easier to leave it out though.
                Messing with electrical stuff makes me nervous as you cant put the magic white smoke back in.
              • Naplm00
                245
                50
                May 20, 2019
                Bay
                Local Time:
                9:31 PM
                i hear you man
              • jau126
                136
                67
                Jun 7, 2020
                Salt Lake City, UT
                Local Time:
                10:31 PM
                Located the power source. Any ideas on connectors to avoid cutting up wires? Factory connector seems a little stubborn to come off
              • toolmanmike
                58,305
                45447
                Jan 18, 2006
                Iowa
                Local Time:
                11:31 PM
                These piggyback connectors are handy.
              • jau126
                136
                67
                Jun 7, 2020
                Salt Lake City, UT
                Local Time:
                10:31 PM
                I guess I will just solder a Little Y in then.
