63dartman
I got a summit fuel pump kit and have some questions about the install.
It says the fuel must be gravity fed to the pump(fuel cell?) Can you run it with the stock tank with out damaging the pump? In the install guide it says that pump could be damaged as it will not stay primed....I really don't want to use a fuel cell but if I have to, What is a good choice for a fuel cell? (20-25 gal). I'm sure once I get this ironed out I will have more questions about the install. Thanks.
