Gator
Mopar or No Car
I am running a Holley electric blue pump and I recently was experiencing fuel problems in which I think I have solved it but I do have a question. When trouble shooting my fuel pump I noticed that it was warm, not on the area where the lines enter and exit but the body where all the enternal parts are. I took a temperature reading in this area with my surface pyrometer and it registered between 85-95 degrees. Is this normal? I have been running this same set up for years and never had the need to touch this pump to see if it was warm. I checked the complete system from the pump to the carb, including the filter and it was all in good shape with no kinks or blockage. I thought that my pump was bad so I replaced it with a new on along with a new regulator and it too gets a little warm so I am thinking that this is normal. What are your guys thoughts on this...
