jonn6464
1970 Duster
Hey FABO,
Here's my issue, as best as I can describe it, and in the order of events.
1- This morning I had incandescent/filament style H4 headlight bulbs and 1157 parking/turn signal bulbs. All were functioning properly. Parking lights came on at first pull stage of knob, headlights came on at second pull stage (parking lights off) and dash gauge lights came on. Front & back, right & left signal lights functioned.
2- I swapped out the H4 headlights for LED replacements. Incandescent parking lights came on at first pull stage of knob, LED headlights came on at second pull stage (parking lights off) and dash gauge lights came on. Front & back, right & left signal lights functioned.
3- I swapped out the 1157 parking/turn signal bulbs for LED replacements. I knew this would most likely require a change to LED compatible flasher, but thought I'd see if it worked. No parking lights, no LED headlights, no dash gauge lights, no turn signal lights.
4- Swapped out 2 pin flasher for 3 pin LED compatible (box says it'll also work with incandescent) and added ground wire to pin 31. Battery power to pin 49, turn signal wire to pin 49A. No parking lights at first pull stage of knob, no headlights at second pull stage, no dash gauge lights. But, front & back, left & right turn signals DO work.
The only thing that stands out in my mind is that when I was swapping out the flasher, the battery power wire and the turn signal wire touched briefly and there was a very small "bzzzzt" and slight spark. No burning smell at all.
Now I have no parking lights, no headlights, and no dash gauge lights.
What am I missing?
Thank you for any info.
What am I missing?
