Will it run (once started) without the jumper wire to the coil?Duster will not start unless i jump coil to battery
It cranks OK tho with the key? So are you saying you got no spark? If that's right then check the ballast resistor. Since you have the jumper wire, just jump across the two terminals. If you have a dual ballast resistor, just jumper all four wires together. Still no spark and electronic ignition, clean the case ground and firewall at the ECU.
If a points system, there are other tests.
But if it doesn't crank with the key, you'll have to check the Fusible-link.
Found out I don’t need a ballast resistor since I have an efi distributor (no points)
Another friend told me to join wires from ballast resistor, is that right?
This is WHY, my friend, it is IMPORTANT to give forth details when you ask a question.
The "run" so called ign1 line goes dead during cranking. Normally, the brown bypass circuit, ign2 supplies ignition voltage during cranking. When you eliminate the ballast you need to connect those two
Well let's take things step by step.......
Just what did you change exactly.
You can put a voltmeter on the V supply line to your ignition, put the key in "run" and see what you have, then turn the key to "crank" and read it during cranking and see what you have.
And what exactly is this system you have? Link? Is this the so called "ready to run" distributor which connects to the stock coil, or is the "big cap" thing that looks like a GM HEI?
