Electronic Ig Control Box on a 85 D100 Off Topic
Slant 6 Engines
  1. Brian Hood
    Brian Hood Well-Known Member
    130
    1
    Jan 10, 2009
    Local Time:
    1:55 PM
    Hey all,I have a 85 D-100 with a dead ignition. It is a slant with a leanburn comp. Is there an Ignition box on this model and where is it located? I CAN NOT FIND IT. Brian
  2. HemiPar
    HemiPar Well-Known Member
    1,721
    6
    Oct 13, 2006
    Kentucky
    Local Time:
    1:55 PM
    Not sure about the lean burn but yes it should have an ignition box. on my 85 2500 Ram it was on the firewall around the master cylinder. You can trace the wires from the distributor to it or look for the 3.5" x 5" box, should have a wire harness with 4 or 5 wires pluged into it. I don't have a pic but that should get you close.
  3. 340mopar
    340mopar Sorgermotorsports
    3,676
    11
    Jan 25, 2006
    Soap Lake, WA
    Local Time:
    11:55 AM
    The lean burn computer should be located towards the front of the truck on the left fender. The air cleaner inlet hose runs to it.
    Chuck
  4. needsaresto
    needsaresto Well-Known Member
    7,807
    202
    Nov 13, 2004
    Local Time:
    11:55 AM
    Toss it and install mopar electronic ign or similar.
  5. 340mopar
    3,676
    11
    Jan 25, 2006
    Soap Lake, WA
    Local Time:
    11:55 AM
    Exactly what I did with my D100 and ran much better. Good advice.
    Chuck
  6. Brian Hood
    130
    1
    Jan 10, 2009
    Local Time:
    1:55 PM
    I found the computer. I know what an electronic ignition box on a Mopar looks like. I just cant seem to find it on this one. Is it built into the computer? It is a slant 6. Anyone?
  7. 66aCUDA
    66aCUDA /6 Racer
    1,026
    5
    Oct 10, 2006
    Marianna, Arkansas
    Local Time:
    1:55 PM
    Yes its built into the computer. To convert to EI you will have to get a new EI distributor and add an EI module. Or go HEI and be MUCH happier. See the HEI conversion over at slantsix.org
    Frank
