Electronic ignition
coronet69swede
sweden
Hi.
On my 67 dart someone updated ignition to mopar stuff before me. Tryed to find but i turn to you. In the foto i would like to know wich color is + and -.
Can i messure to know. It is the conector clossest to the dist. One is brown with tracer and one is grey with tracer. Thanks from springtime sweden.
Johan.
If you are talking about the 2 wire distributor connector it just plugs inot the distributor. It is unlikely, but sometimes rare that the two are reversed, which changes what is called "rotor phasing." Google it
The shop manual in this case is a poor reference because this is added on.
Is your kit a 2 or 4 terminal resistor?
(The deal is, the older / factor ECU was 5 wire box with 4 terminal resistor. The newer and replacement ECU was 4 wire box with 2 wire resistor)
Do NOT go by wire colors necessarily here:
NOTE: The bottom wire YELLOW IS NOT CORRECT. IT does NOT go to the starter relay (which would cause feedback) It goes to the old brown coil bypass wire. IN FACT the factory resistor wiring IS NOT CHANGED from points. The brown bypass should go to the coil + side of the resistor.
To make this "more murky"
YOU DO NOT NEED TO CHANGE the factory resistor wiring, IE to hook up/ replace the points with this:
Remove factory resistor, and plug the new one in its place
"Tap into" the blue switched ignition run wire (top of the resistor) and run the power wire to the ECU as shown
Remove old distributor, and hook black wire from ECU to coil neg, and tachometer at this point if used
Install new distributor and plug 2 wire connector from ECU to distributor
Make CERTAIN ECU is grounded
The point I'm attempting to make.........is that there are actually VERY FEW wiring changes made
IF THIS SYSTEM FAILS and you need to limp home
You can just unplug the ECU and drop in a points distributor and it will run, assuming coil/ resistor/ wiring is OK
