Emulsion Holes on Holley Style Carbs??
hunt2elk
WI
On another current thread there has been a bit of discussion brought up about emulsion holes, but I didn't want to muddy up that thread. So I am looking for some advice as to what these holes actually do and how to tune them and for what circuit they affect.
Specifically on a Quick Fuel Q-850. Each metering block has 8 holes and they all have #28 jets in them.
These carbs also have the idle feed restrictors at the top of the metering blocks. The bottom hole is not tapped to accept a jet. I have read that some people like these jets on the bottom. Is it worth the hassle of tapping out the bottom holes?
Tuner summarizes it here
Keep one near fuel level and one about PV level. Compare to where an old Holley block has them.
If you want three then size down to whatever mark posted over in that forum, around .021 IIRC
Back in the days when Holley was producing thousands, perhaps tens of thousands carburetors for production vehicles they used a restriction in the upwell and even at the top for certain situations. Keeping the fuel jets completely submerged is generally better for predictible fluid flow and more so in engines where pressure differences at idle are unsteady. Hot rods and race engines often have unsteady manifold vacuum at idle.
"Submerged metering passages are free from instability and irregularity of discharge when the head is very small".
Link to NACA TR-49 in this post by Mark Whitener
More in-depth about how e-bleeds work in this discussion
and in this archived discussion with Shrinker from the old Innovate Forum
@TT5.9mag @92b
When you have time, that archived Innovate Motorsports thread includes posts by Tuner mentioning the Avenger carbs and aspiration (emulsion) tubes. He wrote 'early' Avenger carbs which implies the name stayed the same while the product changed.
[/URL]
[/URL]
[/URL]
[/URL]
Thank you, now I have some reading to do.
Found some pics of a Profrom black compared with an old school Holley posted in cudafever's thread
Also I noted a couple posts later that Mark had posted using for the bottom holes for alk applications
