[FOR SALE] Energy Suspension 5.2104G Polyurethane Leaf Spring Bushings (B/E-Body 426/440 type - 1.5")
cudak888
1-Baker-11
USA
NOTE: These are meant for B/E-bodies, but I'm not sure if any aftermarket leaf springs for the A's might use the smaller 1.5" front eyelets to help with spring wrap, so here we go:
This is an unused Energy Suspension 5.2104G set that has been opened (I did a f*cky-wucky and got the set with the 1.5" bushing eyes instead of the 2" set). Otherwise complete except for the grease (I kept that for myself, because I'm greedy and use a lot of it). It includes four of the 1.5" bushings for the front, and eight of the smaller shackle bushings for the rear.
This is supposed to be for factory 440/426 B/E body leafs which (apparently) use a smaller 1.5" front eyelet to the standard 2". I'm told this was to control spring wrap, so I suspect there may be an aftermarket A-body leaf out there that also uses the smaller size. Maybe I'm right...but most likely, I'm wrong - either way, I'm putting this up there in case it might be what you need.
$80 shipped to you in the US or pickup in Miami, Florida. Open to that lovely green paper known as greenbacks or the PayPals (you must cover the fees).
-Kurt
