I’m at the point where I have to decide whether I’m gonna put a J bar in from a Cowell down to the frame in the front of the car it does have fender well header or I wouldn’t even worry about it. What are you guys running or not running
I`m running the J bars. I bought a couple of pieces of 1 5/8' tubing and bent them in a big electricians tubing bender, same as the side bars in my roll cage .I’m at the point where I have to decide whether I’m gonna put a J bar in from a Cowell down to the frame in the front of the car it does have fender well header or I wouldn’t even worry about it. What are you guys running or not running
The inner fenderwell is an integral support structure of the front end along with the front subframe. Yours seem to be still there, helping to support the front. I removed mine to replace them and the last supporting spot weld went out with a bang and the spotweld went of alignment about 2-3mm. The wall thickness of a j-bar may be a little much for an EMT bender unless you used a hydraulic one?
