Engine harness firewall/cowl clips needed 65 barracuda
I found 4 of these in my parts drawer for you, so I'm sending them along!!
As for the wiring harness, I'm still working on that. I have found the plug with a pink/yellow wire inside the drivers side kick panel, but on my 66 convertible it's not plugged into anything. It is not the 2 wire harness you have either, it goes back up through a bigger harness, so I thought the small 2 wire harness you have may go back towards the back of the car. I still need to look through the 64 car, as it is more likely to have this harness in place.
FYI, the 65 dash harness I have also has that plug in the kickpanel location, and it too joins the larger harness going up towards the dash!!
Bottom line, the jury's still out on the small harness!! I'll track it down for yu though!! I'll send the clips out tomorrow, Geof
