Engine ID help
MOA
CA
I did a search and not finding what I'm looking for.
casting is. 11/17/69.
2780930-340-8
I have a couple of blocks to work with and it would be a waste to use this one for what I have in mind. This belongs in a car that is more along the lines of being stock. But I need to know exactly what it is to determine value. Its just the block,main caps and crank.
It's a late 69 casting for a 70 car. There should also be a vin # on it on the oil pan rail.
Oops, meant to include that.
0B61565 stamped at the pan rail.
Can't tell if the first is number or letter
I don't think it's anything special, other than its a 340.
Can you get a clear photo if the numbers on the VIN pad please?
Sure, but I have no way to post it here.
The numbers I posted are correct, very easy to read on the block.
Casting # is 340 used from 68-73. Casting date is for 70 year vehicle. TA blocks have casting #3577130. As above nothing special.
. I know all I need to about it. Thanks.
Ok.
But if you are planning on selling it, I track 1970 Hamtramck (0B) cars & their owners.
Several of them are hoping their original blocks surface, so that is why I asked.
