Engine Identification - need help
Machmeter1
Dayton Ohio
Good evening,
I think a found a year correct engine for my 69 Barracuda. I compared all numbers (Heads, Block, Intake etc.) but here is what confuses me:
The stamped number on the block I want to buy shows PM318R 26142457 (which I believe should have been built on 23. Sep 1968 - would theoretically suit my car built-in 07. Jan1969
The Mopar parts Catalog for 69 gives an example for all 68 engines
Date code 2187 - 24. July 1968
If I put the number 2187 in the maxwedge calculator I get
Date code 2187 - 24. July 1967
So what is now correct - or am I just on the wrong path? Here are screenshots:
Thanks, Wolfgang
2614 is the date code - September 23rd 1968 (1969 model year)
isn't that a casting number rather than a date code?
look on the front, drivers side of the block just under the head for stamped in numbers which would have the model year, CuIn displacement C273 = 67 model year 273
Build date 12-6 = Dec 1966 (car delivered 2-67)
Good evening,
Thanks, Wolfgang
The last 8 digits on the block under the left side head are for date code and sequential number of engines built that day....
How to ID a Small Block Engine Block:
Krazycuda, btw your articles are really informative - thanks for sharing your experience.
