1. oley340
    oley340 Active Member
    25
    4
    Jan 26, 2010
    Local Time:
    10:57 PM
    Looking for help or opinions... i have 340 stroked to a 416 as of late on start up it has developed a loud clanking sound that lasts around a minute or so. after that it is fine no power loss. Any help on this matter would be great Thanks
  2. Lelo Dart
    Lelo Dart *
    1,356
    335
    Oct 10, 2012
    Knob Noster MO.
    Local Time:
    10:57 PM
    Could be piston rock/slap. Classic on a stroker engine. The short forged pistons tend to rock in the cylinder and make that noise. After they warm up the clearance is taken up and the noise stops.
    • Agree Agree x 2
    • Like Like x 1
    • moper
      moper FABO Gold Member FABO Gold Member
      15,532
      1633
      Dec 27, 2004
      eastern CT
      Local Time:
      4:57 AM
      Clanking - like a metallic sound or more of a knock like you'd hear on a wood door? Pistons don't "ring". If it's more metallic ringing i'd look elsewhere.
      • Agree Agree x 1
      • Max1196
        Max1196 Well-Known Member
        660
        363
        May 12, 2016
        Swift Current SK
        Local Time:
        9:57 PM
        Auto or standard trans?
      • diymirage
        diymirage HP@idle > hondaHP@redline
        15,172
        7593
        Oct 12, 2012
        michigan
        Local Time:
        11:57 PM
        • Like Like x 4
        • TrailBeast
          TrailBeast Slightly Twisted Member
          19,615
          6093
          Mar 11, 2011
          Arizona
          Local Time:
          8:57 PM
          If an automatic the VERY FIRST thing to check is the converter bolts.
          It's common for loose bolts on the converter to sound like a knock, AND really common for it to go away after the converter starts warming up.
          If a stick, flywheel bolts can come loose and sound like a engine knock.
          If that ends up being what it is blue Loctite keeps that from happening again. (usually):D
          • Agree Agree x 1
          • Vamisk
            Vamisk Well-Known Member
            197
            56
            Nov 2, 2016
            Pennsylvania
            Local Time:
            11:57 PM
            While you're there, check for wasted lifters. Seems like every chevy I own develops a tick that goes away after about 10 min of driving
          • stixx
            stixx FABO Gold Member FABO Gold Member
            596
            381
            May 30, 2006
            Southern Germany
            Local Time:
            4:57 AM
            Well, a clanking sound sure is different than a tick from a lifter?
            OP needs to describe better... where does it originate, give us an audio...
            • Agree Agree x 1
            • oley340
              25
              4
              Jan 26, 2010
              Local Time:
              10:57 PM
              Thanks guys gives me a lot to look at
            • oley340
              25
              4
              Jan 26, 2010
              Local Time:
              10:57 PM
              I will check that Thanks
            • oley340
              25
              4
              Jan 26, 2010
              Local Time:
              10:57 PM
              Turned out to be the harmonic ballancer had seperated thanks for all your help.
              • Like Like x 2
              • Thanks! Thanks! x 1
              • nm9stheham
                nm9stheham Well-Known Member
                10,562
                2778
                Dec 20, 2013
                Waynesboro, VA
                Local Time:
                11:57 PM
                Glad you caught that? Is this the original one, or do you know the brand?
