Engine Mounts to go on Spool type K-Member.
Big Block A body Tech
  1. m79ded
    m79ded Member
    18
    6
    Nov 21, 2017
    NY
    Local Time:
    2:24 PM
    Hi
    I got a 73 Duster with a V8 K-member whick is a Spool type and I want to put in my B engine. I called Schumacher and their mounts are on back order, with that said any other alternatives? I really don't want to put ears on the waterpump cause of rattling, Anyone out there have any of those mounts that I can buy? Any help will be appreciated I would like to get the car on the road.
    Thanks
  2. toolmanmike
    toolmanmike FABO Staff Staff Member FABO Gold Member
    36,133
    18275
    Jan 18, 2006
    Iowa
    Local Time:
    1:24 PM
    Classic Industries has them listed. They may have them in stock.
    • Thanks! Thanks! x 2
    • m79ded
      m79ded Member
      18
      6
      Nov 21, 2017
      NY
      Local Time:
      2:24 PM
      Part is backorder 6 weeks,
    • toolmanmike
      36,133
      18275
      Jan 18, 2006
      Iowa
      Local Time:
      1:24 PM
      Start a "wanted" thread with the part numbers.
    • AndyF
      AndyF Well-Known Member
      1,201
      799
      Feb 23, 2009
      Oregon
      Local Time:
      11:24 AM
      If you are using a DC type of K member with the spool mount brackets moved back to the correct location for a big block then you can use stock motor mounts. You don't need to buy the Schumacher poly mounts, just buy replacement spool mounts from a local auto parts store. If you are trying to do a conversion using a SB K frame then you'll need to buy conversion motor mounts.
      • Thanks! Thanks! x 1
      • m79ded
        m79ded Member
        18
        6
        Nov 21, 2017
        NY
        Local Time:
        2:24 PM
        Hi Andy
        That's the road it looks like i'm going to go with because I can't seem to locate conversion mounts anywhere. Another option is to put a QA1 k-member if it will accept a B engine, A further option is to reweld the perches on the spool type k-members similar to the DC type.
        Thanks for the info and for pointing me on the right track. If you get a lead on mounts or K-member please contact me.
      • Jim Lusk
        Jim Lusk Well-Known Member
        3,904
        335
        Mar 8, 2006
        Fresno, CA
        Local Time:
        11:24 AM
        Watch my videos. It's easy to build a DC k-member. Then all you need are the 74-78 passenger car big block motor mounts.
        • AndyF
          1,201
          799
          Feb 23, 2009
          Oregon
          Local Time:
          11:24 AM
          Watch the videos and then go after it if you have the tools and the talent. If not then maybe find someone local who can do it. If that doesn't work out then box up your K frame and ship it to Jim and let him build you a DC type K frame.
          • Like Like x 1
          • george joseph reid
            george joseph reid Well-Known Member
            81
            34
            Aug 22, 2018
            Elmira Oregon
            Local Time:
            11:24 AM
            Just did this on my 73 with the Shumacher mounts on a Slant K. Used the reniforcement weld on kit and mods. One thing to note is dip stick placement. Had to do a bit of grinding one one of the K ears, no biggie though.
          • 604B1duster
            604B1duster Well-Known Member
            981
            311
            Dec 30, 2007
            Local Time:
            12:24 PM
            I have the mounts you need, PM sent
          • m79ded
            m79ded Member
            18
            6
            Nov 21, 2017
            NY
            Local Time:
            2:24 PM
            PM Sent
