Engine placement
New Hemi Engine Swaps
  1. TheGreatGazoo
    TheGreatGazoo Member
    20
    14
    Aug 14, 2019
    New York
    Local Time:
    5:11 PM
    so I'm in the middle of installing me 5.7 in my 66 valiant "early A body". does anyone know should the center of the crank be centered between the frame rails. it seems to be in a happy spot slightly off to the passenger side.
  2. ragtopfury
    ragtopfury Well-Known Member
    3,088
    2892
    Jul 14, 2011
    Manchester, MD
    Local Time:
    5:11 PM
    Aren't they all set a little to the passenger side? Hence less clearance on the right side inner fender on all V8s in our A Bodies.
    • Agree Agree x 2
    • Syleng1
      Syleng1 Karma is real and Life is short... FABO Gold Member
      2,324
      1975
      Jul 5, 2005
      North Franklin, CT
      Local Time:
      5:11 PM
      Typically the early a- small blocks were off set to the passenger side due to the steering box.
      • Agree Agree x 2
      • TheGreatGazoo
        20
        14
        Aug 14, 2019
        New York
        Local Time:
        5:11 PM
        i
        it looks like it is if someone has a measurement it would help alot
      • Alaskan_TA
        Alaskan_TA Well-Known Member
        6,099
        4628
        Nov 12, 2004
        PA
        Local Time:
        5:11 PM
        The engines are offset to accommodate the steering box and column.
        • Agree Agree x 1
        • Treblig
          Treblig Well-Known Member
          7,313
          4801
          Oct 5, 2013
          South Texas
          Local Time:
          4:11 PM
          People were fatter back in the day so they moved the engine over to the passenger's side to compensate for the extra weight on the driver's side.:rofl::mad::poke:
          • Thanks! Thanks! x 3
          • Like Like x 1
          • kursplat
            kursplat FABO Gold Member FABO Gold Member
            4,207
            3143
            Aug 24, 2010
            so cal
            Local Time:
            2:11 PM
            use the C/L of the tunnel to the pinyon, that should get you close
            • Like Like x 1
            • inertia
              inertia Well-Known Member
              3,537
              819
              Feb 4, 2011
              Victoria B.C. Canada
              Local Time:
              2:11 PM
              • Like Like x 2
              • krazykuda
                krazykuda Well-Known Member FABO Gold Member How-To Section Editor
                59,693
                25766
                Aug 20, 2007
                Orland Park, IL
                Local Time:
                4:11 PM
                Just get it between the fenders....
              • TheGreatGazoo
                20
                14
                Aug 14, 2019
                New York
                Local Time:
                5:11 PM
                Perfect! thats exactly what im looking for!!!
              • TheGreatGazoo
                20
                14
                Aug 14, 2019
                New York
                Local Time:
                5:11 PM
                ok made good progress today got the motor in and almost ready to fab mounts. what would you guys think would be a good downward angle.
              • inertia
                3,537
                819
                Feb 4, 2011
                Local Time:
                2:11 PM
                For your viewing pleasure !
