Engine smoking advice
Small Block Mopar Engine
  1. jimmyray
    jimmyray Well-Known Member
    1,033
    12
    Jul 17, 2007
    Local Time:
    1:55 PM
    I have a 66 Barracuda with an original 273, never gone through as far as I can tell. has 119k+ miles (speedo broken for several years) It is using oil and smokes quite a bit at startup and under WOT, sometimes just at idle! Normally, I would assume a worn ring issue, but I did a compression check, and all 8 cylinders ranged from 135-155 psi! I swapped out the valve guide seals, there were very hard and brittle, and several crumbled. Only helped marginally. I did notice the valves moved in the guides slightly when I pushed on them.
    I tried some 20W50 and some oil thickener (stop smoke crap) and it may actually be worse.
    I really don't want to pull the engine. Perhaps just a head rebuild? How hard is it to re-ring the motor while in the car? Thoughts?
  2. 805moparkid
    805moparkid Slant and AFX Guy
    11,533
    87
    Oct 29, 2008
    Anthem AZ
    Local Time:
    12:55 PM
    could be that ur pvc is stuck and is sucking in oil... and also are u sure that its the engine smoking and not hot oil leaking from a gasket and hitting a header...
  3. jimmyray
    1,033
    12
    Jul 17, 2007
    Local Time:
    1:55 PM
    Yes, it is definitely coming out of the tailpipes, and a brand new PCV.
  4. dodge freak
    dodge freak Well-Known Member
    3,991
    35
    Nov 5, 2006
    Too close to Detroit, lol
    Local Time:
    2:55 PM
    That freaking motor is 44 years old and you want to do a re-ring with the motor in the car--like its 10 years old, I say you are wasting your time.
    However it can be done but not the cam bearings. Even the main bearings are going to be a hassle.
    I would not do it. You could pull the heads and have them re-built but dropping the oil pan and knocking each piston out and honing the cylinders, you need to turn the crank journals down out of the way and watch you don't hit them, seems like lots of work for a short term gain. What if it still smokes cause it needs oversize pistons?
    Sorry, I don't think its a good idea. Its a gamble.
  5. T67POWER
    T67POWER Well-Known Member
    669
    1
    Sep 30, 2009
    Local Time:
    2:55 PM
    Advance your timing.
    It will help burn the oil off.
    Use a hotter spark plug also.
    You most likely have worn guides.
    Buy a new set of heads at aero racing for $399.a pair.
    509 springs with new guides and seals \\ all rebuilt.
  6. dodge freak
    3,991
    35
    Nov 5, 2006
    Local Time:
    2:55 PM
    The compression might look ok with all the oil on the rings right now.
    No harm is just taking the heads off and replace/rebuild them and see what happens. Always a chance oil is leaking from the intake gasket and getting suck in to the intake ports.
  7. 340 8BBL
    340 8BBL Well-Known Member
    708
    2
    May 19, 2009
    in the woods
    Local Time:
    11:55 AM
    good point,might be a leaking intake gasket.cranking compression does not tell the whole story,a leak-down test may help detect worn rings.
  8. RustyRatRod
    RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
    65,813
    39122
    Jun 7, 2010
    Georgia
    Local Time:
    2:55 PM
    First, the compression rings have notta thing to do with oil consumption. Nuthin. Second....if you want to stretch it out a bit until the rebuild....which it DOES need, here is a tip. I normally absolutely DETEST engine oil and fuel additives, but through the years, I've found one that really works. It's called. Restore. It comes in a chrome can and is available at any auto parts store. It fills in scratches in the cylinder walls and restores compression and also helps the oil rings restore theor sealing function. I've used it and was pleased everytime. You do however, have to buy a new can with every oil change. Good luck.
  9. green1
    green1 Well-Known Member
    4,668
    18
    Dec 6, 2008
    Orange Park, Fla
    Local Time:
    1:55 PM
    So you are saying the 2nd ring does nothing for oil control? Isn't it a scraper?
  10. bonehead
    bonehead Well-Known Member
    130
    0
    Jun 20, 2010
    ar
    Local Time:
    1:55 PM
    1964 if you got 50 k on your engine it was worn out . had to turn speedo back to sell one they would live longer with good care .you have to remember that we traded car every two years. auto companys knew that and built cars that would last for that ....mopar built a car with 5 yr 50k waranty witch caused them to go belly up ........if you cant stand the smoke you are much better off pulling engine and do it right rebuild it will give you lots of enjoyable miles......bonehead
  11. 340mopar
    340mopar Sorgermotorsports
    3,676
    11
    Jan 25, 2006
    Soap Lake, WA
    Local Time:
    11:55 AM
    Smoking at start up = valve guides. Smoke at = WOT rings. She is tired.
    Chuck
  12. bigdemo1
    bigdemo1 Well-Known Member
    890
    2
    Mar 15, 2009
    Local Time:
    1:55 PM
    buy a vacuum guage,it will tell you what is worn
  13. ramcharger
    ramcharger Dismember
    14,143
    119
    Nov 15, 2005
    Lakewood, Colorado
    Local Time:
    12:55 PM
    Engine Smoking Advice? I've always found it quite difficult to roll an engine in a paper, have you considered a large pipe? :read2:
    Just kidding. :)
    340mopar is right. Smoking on startup or deacceleration is valve guides. Smoking on WOT and cruise is worn rings. Sounds like you have both and it's just tired.
  14. bumnround
    bumnround Well-Known Member
    340
    1
    Oct 25, 2008
    Local Time:
    1:55 PM
    I've got that exact same tired 273 in a 67 cuda. I got a fresh 360 to go in this winter.
  15. goldfish65
    goldfish65 Well-Known Member
    10,146
    5679
    Aug 22, 2008
    Johns Island, SC
    Local Time:
    2:55 PM
    Oil additive called tx7, I was very skeptical but it's amazing how much it has reduced the smoking and oil consumption on my '65 273.
